1 2 Previous Next 41 Replies Latest reply on Aug 13, 2012 6:38 AM by Claudio Cesar Filho
    PMD View blank in Flash Builder Beta 2 Standalone
    robdodson
      Following the instructions on the wiki I downloaded the plugin through the help menu in FB from here: http://opensource.adobe.com/svn/opensource/flexpmd/plugin/trunk/flex-pmd-eclipse-plugin-si te
      Plugin is configured in preferences with the following settings:
      FlexPMD command line installation: /Users/{myName}/Tools/FlashBuilder_Plugins/flex-pmd-all-in-one-bundle-1.0.1/flex-pmd-comm and-line-1.0.jar
      FlexPMD custom ruleset: (blank)
      Java command line: java -Xmx256m
      FlexCPD command line installation: /Users/{myName}/Tools/FlashBuilder_Plugins/flex-pmd-all-in-one-bundle-1.0.1/flex-pmd-cpd- command-line-1.0.jar
      Minimum tokens: 25
      When I select a folder and say 'Run FlexPMD' it opens the FlexPMD view but there is no output.
      Currently testing on an actionscript only file. Does the project have to use MXML?
        • 1. Re: PMD View blank in Flash Builder Beta 2 Standalone
          Conrad LFS
          Same issue here,
          I am using the latest drop of flash builder - 262635 (I am on the prerelease program). I am using the plugin with Eclipse 3.5.
          CPD works very well (and surprisingly fast), but PMD shows no output with rule set blank. I have no custome ruleset to test against.
          • 2. Re: PMD View blank in Flash Builder Beta 2 Standalone
            Xavi Beumala Level 1
            can you make sure you download FlexPMD 1.0.1 from http://opensource.adobe.com/svn/opensource/flexpmd/maven-repository/release/com/adobe/ac/f lex-pmd/1.0/flex-pmd-all-in-one-bundle-1.0.1.zip
            I see you're using /fle x-pmd-command-line-1.0.jar instead of 1.0.1
            This should fix your issue.
            Cheers
            Xavi Beumala
            • 3. Re: PMD View blank in Flash Builder Beta 2 Standalone
              Ben Smeets
              Hi, having the same problem. CPD works, but PMD shows an empty view. (FB3).
              I downloaded the sipfile you mentioned, but not sure how you recognized him using the 1.0 instead of 1.0.1 because all the files are still named xxx-1.0.jar, even in the 1.0.1 zipfile. Is that ok?
              Ben
              • 4. Re: PMD View blank in Flash Builder Beta 2 Standalone
                Hi Ben,
                you're right, files have the 1.0 naming.
                Can you give me some further details on your environment? FB version and eclipse version?
                Can you see the "running FlexPMD" process message in the bottom right corner?
                Is the nature also failing or is only the "run flexPMD" right-click action?
                If you open "error log" view on Windows > Show views > Other > Error log can you see any error in there?
                Xavi
                • 5. Re: PMD View blank in Flash Builder Beta 2 Standalone
                  odoenet
                  I'm having same issue in Flex Builder 3 Standalone Version: 3.0.205647.
                  FlexCPD runs fine, right-click FlexPMD, I can briefly see the green progress status in bottom corner, but nothing happens. I downloaded the 1.0.1 zip, but all file names are 1.0. Thanks.
                  • 6. Re: PMD View blank in Flash Builder Beta 2 Standalone
                    Ben Smeets Level 1
                    Some more info:
                    - the green running bar blinks for .5 seconds
                    - Command line running of flexpmd works great
                    - flexCPD works through the pluging (including the view)
                    - add FlexPMD nature works
                    - cannot seem to find the error log view
                    - Using Flex builder 3 build 3.0.2.214193
                    - Eclipse version: 3.3.1.R33x_r20070911-_19UEkpF-B7Uh2hKy75y
                    • 7. Re: PMD View blank in Flash Builder Beta 2 Standalone
                      When you add flexPMD nature and compile can you see FlexPMD violations in the standard error view?
                      Are you in FB standalone?
                      • 8. Re: PMD View blank in Flash Builder Beta 2 Standalone
                        odoenet Level 1
                        I added FlexPMD Nature, compiled and have no errors
                        Using FlexBuilder 3 stand-alone.
                        • 9. Re: PMD View blank in Flash Builder Beta 2 Standalone
                          Ben Smeets Level 1
                          The only error view I can turn on, is the normal Flex Builder "problems" view. Nothing is shown there.
                          I am in Flex builder standalone yes.
                          Ben
                          • 10. Re: PMD View blank in Flash Builder Beta 2 Standalone
                            marteinn_se
                            I also have the same problem with no errors beeing returned, just a empty view. I'm running osx 10.5 (intel) with Flash Builder beta 2 (eclipse 3.4.0). And of course with the latest plugin version 1.0.1.  PMD does not work but the find cut/paste works perfect.
                            But I suspect that this is a workspace specific bug, beacuse I hooked up pmd on another workspace and it worked perfectly. So finally I tested to remove my current workspace (the one where pmd did not start) and create a new one from scratch, but pmd still wouldnt run. It's wierd.
                            Cheers
                            / Martin
                            • 11. Re: PMD View blank in Flash Builder Beta 2 Standalone
                              tinylion_uk Level 2
                              I'm also getting blank view panels. Errors/warning/info showing fine in the problems panel
                              using lastest version of everything as far as i know.
                              screen shot so you can see what i mean. also noticed in outline panel, on docs there's an icon, on my version its a "monitorize' button. see pic
                              really like what you have done so far, and looking forward to the future of this tool. Already finding it usefull
                              cheers
                              glenn
                              • 12. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                Ben Smeets Level 1
                                I tried adding the nature to another workspace as well, no luck for me.
                                • 13. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                  devertex
                                  I have the same error. Tried the same setup on a new workspace and worked perfectly. Here is the error I get in the log with the default workspace ( maybe some lines are irrelevant ):
                                  !ENTRY org.eclipse.ui 2 0 2009-12-13 18:18:02.754
                                  !MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
                                  !SUBENTRY 1 org.eclipse.ui 2 0 2009-12-13 18:18:02.754
                                  !MESSAGE Cannot bind to an undefined command: plug-in='com.adobe.ac.pmd.eclipse', id='com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category'
                                  !ENTRY org.eclipse.ui 4 4 2009-12-13 18:18:03.663
                                  !MESSAGE Unable to create menu item "com.adobe.ac.pmd.eclipse.toolbar.runCommand", command "com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category" not defined
                                  • 14. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                    Hi Glenn,
                                    looking at your screenshot I can only see 1 error. The outline view should display the errors in your active editor. We have a known issue that if FlexPMD is executed while file is opened the outline View won't be updated the first time.
                                    A part from that everything else looks fine to me. Remember that when you run FlexPMD as a nature FlexPMD view won't display anything. FlexPMD view is only used when FlexPMD is executed manually.
                                    Regarding the icon issue I've logged a bug for it: http://bugs.adobe.com/jira/browse/FLEXPMD-123
                                    Cheers
                                    Xavi Beumala
                                    • 15. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                      @Martin I've filled in a new bug in Jira regarding the workspace problem you're experiencing http://bugs.adobe.com/jira/browse/FLEXPMD-124
                                      Please, can you add any further information you have as well as the workspace logs so that I can have a look please? You can find the logs in the your workspace root folder under ./metadata/.log If possible clean up the log file, launch eclipse and try to add pmd nature and clean your project.
                                      Xavi Beumala
                                      • 16. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                        @devertex @Ben @odoenet @scruffpuff
                                        I've discovered an issue that might end up not running / displaying FlexPMD results. If your preferences point to a wrong jar or to a bad location the plugin will fail silently. I don't think this is the case for @scruffpuff but it's worth you all check your preferences params. The most important one is FlexPMD command line installation which should point to flex-pmd-command-line-1.0.jar
                                        If this doesn't fix the problems, which I guess won't for all of you, could you please run eclipse from the command line with the -debug option?
                                        Win: eclipse.exe -debug
                                        OSX: {eclipse_folder}/Eclipse.app/Contents/MacOS/eclipse -debug
                                        Then right-click in a source folder an execute FlexPMD > Run FlexPMD
                                        After that you should see some information in the console with further information on what's failing. Could you paste the information here?
                                        I've logged in a bug and an ehancement request:
                                        FlexPMD fails silently:
                                        http://bugs.adobe.com/jira/browse/FLEXPMD-125
                                        Improve installation process / user experience:
                                        http://bugs.adobe.com/jira/browse/FLEXPMD-126
                                        Cheers
                                        Xavi Beumala
                                        • 17. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                          marteinn_se Level 1
                                          Here's my output from FlashBuilder debug.
                                          Application Started: 20997
                                          2009-12-13 20:26:03.824 FlashBuilder[71219:10b] Error loading /Library/Contextual Menu Items/StuffItCM.plugin/Contents/MacOS/StuffItCM:  dlopen(/Library/Contextual Menu Items/StuffItCM.plugin/Contents/MacOS/StuffItCM, 262): no suitable image found.  Did find:
                                          /Library/Contextual Menu Items/StuffItCM.plugin/Contents/MacOS/StuffItCM: mach-o, but wrong architecture
                                          2009-12-13 20:26:03.824 FlashBuilder[71219:10b] Cannot find function pointer MyCMPluginFactory for factory 02E3F072-9CCB-11D5-A0B2-00306575F8A2 in CFBundle/CFPlugIn 0x4d3c6a40 </Library/Contextual Menu Items/StuffItCM.plugin> (bundle, not loaded)
                                          Dec 13, 2009 8:26:07 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
                                          INFO: java -Xmx256m -jar /Applications/flex-pmd-all-in-one-bundle-1/flex-pmd-command-line-1.0.jar -s /Users/martinsandstrom/workspaces/***/*********/*******/src -o /var/folders/+G/+GG-a7t-Fu4gIp8SXBVd6E+++TI/-Tmp-/flexpmd8949488189652837549dir
                                          Dec 13, 2009 8:26:07 PM com.adobe.ac.pmd.eclipse.utils.cli.ErrorLogDevice log
                                          WARNING: 2009-dec-13 20:26:07 com.adobe.ac.pmd.commandline.FlexPMD areCommandLineOptionsCorrect
                                          WARNING: ALLVARLIG: Usage: java com.adobe.ac.pmd.commandline.FlexPMD (-s|--sourceDirectory) <sourceDirectory> (-o|--outputDirectory) <outputDirectory> [(-r|--ruleSet) <ruleSet>] [(-e|--excludePackage) <excludePackage>]
                                          SEVERE: /var/folders/+G/+GG-a7t-Fu4gIp8SXBVd6E+++TI/-Tmp-/flexpmd8949488189652837549dir/pmd.xml (No such file or directory)
                                          • 18. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                            devertex Level 1
                                            It seems I found the problem. I tried to create a new workspace with a space in the path and I got the error. I tried to find some secret config in the .metadata folder without result. Maybe it's in the plugin that the path is not converted form "/path to/" to "/path\ to/" or the oposite.
                                            • 19. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                              marteinn_se Level 1
                                              That might be the problem. Beacuse the workspace I am having trouble with contains a space in the workspace name,
                                              / M
                                              • 20. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                Hi Martin,
                                                looking at your code, the interesting / important part is:
                                                It looks like the problem comes from /Users/martinsandstrom/workspaces/***/*********/*******/src Is there any white space in this path?
                                                • 21. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                  marteinn_se Level 1
                                                  Sorry about that, I had to censor it for client purposes
                                                  But yes, it contains a space. To be more exact, the workspace name contains a space, like this = "workspace 2".
                                                  • 23. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                    marteinn_se Level 1
                                                    Thats great. Will do a re-checkout of my troubling project tomorrow morning and see how it goes, i'm sure it will work like a charm.
                                                    Great findings everyone!
                                                    / M
                                                    • 24. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                      odoenet Level 1
                                                      I'm getting a similar error on Windows 7 Pro.
                                                      It looks like it's trying to write to an output directory in my user directory, but can't. So, I have FlexBuilder 3 and the SDK Command Prompt both set to run as administrator and still no go. I moved the FlexPMD command files to my FlexBuilder 3 plug-ins folder and no go.
                                                      All the temp folders it attempted to make are empty.
                                                      Thanks.
                                                      Dec 13, 2009 12:22:12 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
                                                      INFO: java -Xmx256m -jar C:\Flex\flexpmd\flex-pmd-command-line-1.0.jar -s C:\Users\odoe\Documents\Flex Builder 3\WDORS -o C:\Users\odoe\AppData\Local\
                                                      Temp\flexpmd42452dir
                                                      Dec 13, 2009 12:22:13 PM com.adobe.ac.pmd.eclipse.utils.cli.ErrorLogDevice log
                                                      WARNING: Dec 13, 2009 12:22:13 PM com.adobe.ac.pmd.commandline.FlexPMD areCommandLineOptionsCorrect
                                                      WARNING: SEVERE: Usage: java com.adobe.ac.pmd.commandline.FlexPMD (-s|--sourceDirectory) <sourceDirectory> (-o|--outputDirectory) <outputDirectory> [(
                                                      Dec 13, 2009 12:22:13 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
                                                      SEVERE: C:\Users\odoe\AppData\Local\Temp\flexpmd42452dir\pmd.xml (The system cannot find the file specified)
                                                      • 25. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                        @odoenet
                                                        Your problem seems to be the same regarding the spaces. There're spaces in the path of your workspace: C:\Users\odoe\Documents\Flex Builder 3\
                                                        The log is not explicit about that and it says the pmd folder doesn't exist, but the cause problem comes from the spaces... Can you try executing PMD in a project / workspace without spaces?
                                                        Cheers
                                                        Xavi
                                                        • 26. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                          odoenet Level 1
                                                          Thanks. Switching to a workspace with no spaces and works great!
                                                          Posted earlier before finishing reading the current replies.
                                                          Thanks.
                                                          • 27. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                            Ben Smeets Level 1
                                                            Nice to see the possible solution. I can't change the path to something without spaces though. Hope PMD will be updated soon to allow for this. (The view I mean, because PMD itself has no problems with it ).
                                                            Cheers, Ben
                                                            • 28. Re: PMD View blank in Flash Builder Beta 2 Standalone
                                                              Ben Smeets Level 1
                                                              Couldn't help myself and did a quick test in a workspace without spaces, that fixed the problem for me.
                                                              Ben
                                                              • 29. Re: PMD View blank in Flash Builder Beta 2 Standalone
        robdodson Level 1
        I switched workspaces by going to File > Switch workspace and then chose one which did not have any spaces (by default my workspace said Adobe Flash Builder Beta 2). I imported my preferences and tried to run PMD on a project I'm sure is full of problems. Still getting a blank view though. Is there more to switching workspaces than the steps I've listed?
        *Edit*
        Just to clarify, my new workspace path is Users/{myName}/Projects
        When I go to Preferences > General > Workspace > Linked Resources
        I see only 1 entry which reads DOCUMENTS - /Users/{myName}/Documents/Adobe Flash Builder Beta 2
        Does this need to be changed as well?
        • 30. Re: PMD View blank in Flash Builder Beta 2 Standalone
        flex2008
        I am using flexbuilder 3 standalone.PMD view is blank.But I am able to run the PMD from the command line though.Workspace and the project i tried does not contain any blank spaces.
        • 31. Re: PMD View blank in Flash Builder Beta 2 Standalone
        @flex2008 @scruffpuff
        Can you please follow these steps:
        - run eclipse from the command line with -debug option
        - invoke flexPMD from eclipse (right click in source folder > FlexPMD > Run FlexPMD)
        Paste here your relevant logs from the console window
        • 32. Re: PMD View blank in Flash Builder Beta 2 Standalone
        robdodson Level 1
        I don't have Flash Builder installed as an Eclipse plugin, rather I'm using the stand alone version. So I ran Flash Builder Beta 2 debug from the command line. Hope that's correct. Here's the output I got when trying to run PMD on a src folder:
        Dec 15, 2009 12:53:16 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
        INFO: java -Xmx256m -jar /Users/robdodson/Tools/FlashBuilder_Plugins/flex-pmd-all-in-one-bundle-1.0.1/flex-pmd-com mand-line-1.0.jar -s /Users/robdodson/Projects/015_PUSHY/pushycat_fb_sokoban/trunk/src -o /var/folders/j2/j2HcmtGIH4iXMynRyqUXGE+++TI/-Tmp-/flexpmd672037167065534572dir
        Dec 15, 2009 12:53:17 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
        SEVERE: /var/folders/j2/j2HcmtGIH4iXMynRyqUXGE+++TI/-Tmp-/flexpmd672037167065534572dir/pmd.xml (No such file or directory)
        • 33. Re: PMD View blank in Flash Builder Beta 2 Standalone
        robdodson Level 1
        the way this pasted into the comment window, at least for me, it looks like there is a space where it says 'dir/ pmd.xml'
        however, it doesn't look like there is a space in the command line output, so maybe it's weird text formatting on the part of the forum? just wanted to point that out.
        *edit*
        it also seems to do it on this line '/Users/robdodson/Tools/FlashBuilder_Plugins/flex-pmd-all-in-one-bundle-1.0.1/fl ex-pmd-command-line-1.0.jar'
        where it says flex-pmd-command-line-1.0.jar. But in terminal it does not have extra spaces between the words.
        • 34. Re: PMD View blank in Flash Builder Beta 2 Standalone
        robdodson Level 1
        Can anyone checkout my log file and let me know if anything stands out as missing or screwed up? I still haven't been able to get PMD to work :/
        • 35. Re: PMD View blank in Flash Builder Beta 2 Standalone
        João Saleiro
        I have tried FlexPMD with almost all possible combinations - with Flex 3, with Flex 4 Standalone, with Flex 4 Plugin, using workspace with space, without space, using my C: partition, my D partition, etc. Without being able to see anything at all on the FlexPMD view.
        After finding this forum, I have tried running eclipse with -debug, and got this stack trace:
        Application Started: 16427
        Jan 14, 2010 7:38:24 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
        INFO: java -Xmx256m -jar D:\bin\FlexPMD\flex-pmd-command-line-1.0.jar -s C:\test
        e\fdaga -o C:\Users\JOOSAL~1\AppData\Local\Temp\flexpmd3892770551481749445dir
        Jan 14, 2010 7:38:29 PM com.adobe.ac.pmd.eclipse.utils.cli.ErrorLogDevice log
        WARNING: 14/Jan/2010 19:38:29 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine <in
        it>
        WARNING: WARNING: Access is denied at java.io.WinNTFileSystem.createFileExclusiv
        ely(Native Method)
        WARNING: java.io.File.checkAndCreate(Unknown Source)
        WARNING: java.io.File.createTempFile(Unknown Source)
        Jan 14, 2010 7:38:29 PM com.adobe.ac.pmd.eclipse.flexpmd.cmd.FlexPMD process
        SEVERE: C:\Users\JOOSAL~1\AppData\Local\Temp\flexpmd3892770551481749445dir\pmd.x
        It seems the problem might be due to my User Account in Windows, which have spaces and special characters (João Saleiro) - but I might be wrong. I can't change my user account name, which makes FlexPMD useless for now. And I was hoping to show it on a presentation I will be giving for the community next saturday (day 16). Is there any workaround that allows me to use FlexPMD inside eclipse, so I can use it for now? Isn't there an easy way to set the output directory to a different one?
        Thank you,
        João Saleiro
        • 36. Re: PMD View blank in Flash Builder Beta 2 Standalone
        Hi Joao,
        I'm sorry to hear the plugin is not working on your environment. I'm almost sure it's because of your home directory. I'm afraid I won't be able to provide you a fix / workaround for this before tomorrow
        the way we're currently getting the output folder is with the Java File API: File.createTempFile So it's java who chooses where to create this temp file... I'm not sure if Java provides a way to change this location.
        • 37. Re: PMD View blank in Flash Builder Beta 2 Standalone
        João Saleiro Level 1
        Xavi,
        what about if the user can set the output directory on the preferences of the plugin? I can imagine cases where I would like to keep the PMD generated report, and for that I would be glad to output it to a directory set by me. What do you think?
        João Saleiro
        www.webfuel.pt
        www.riapt.org
        • 38. Re: PMD View blank in Flash Builder Beta 2 Standalone
        davr64
        I'm having the same problem. I posted my logs to the bug report page before I found this page, so I wont duplicate them here. See them here:
        http://bugs.adobe.com/jira/browse/FLEXPMD-120
        I have no spaces in my project, workspace, PMD commandline jars, or windows user home paths.
        The exact same command listed in the console as failing, works when I run it manually on the commandline.
        I forgot to mention in the bug, my versions are:
        Flash Builder: Version 4.0 (build 253292)
        Eclipse Platform: Version: 3.4.2 Build id: M20090211-1700
        OS: Windows Vista SP2 32-bit
        I've tried running FlexPMD both as a build nature (it added no warnings/errors to my flex 'problems' panel) and as a command (the FlexPMD View opens after running it, but it's empty)
        • 39. Re: PMD View blank in Flash Builder Beta 2 Standalone
        It looks like the problem with mine was not the Windows user account, but the fact that Windows (I'm using Windows 7) was not allowing JAVA to write to the Temp directory. Running Eclipse as Administrator solved my problem.
        Hope this helps
        1 2 Previous Next
