1. Re: Usage of Acrobat Color layer
lrosenth Dec 11, 2009 3:18 AM (in response to joeln3)When you say application, do you mean PDFLibrary-based application? If so, AC is supported.
2. Re: Usage of Acrobat Color layer
Bernd Alheit Dec 11, 2009 3:40 AM (in response to joeln3)Unfortunately the AC functions are not defined when I build the application.
The functions are defined in AcroColorProcs.h.
3. Re: Usage of Acrobat Color layer
joeln3 Dec 13, 2009 11:56 PM (in response to lrosenth)Actually this is a plug-in application.
Concenring the "AcroColorCalls.h" I included the "PIHeaders.h" in thmy header so the functions should be found.
My error message is : error C3861: 'ACGetWorkingSpaceProfile': identifier not found.
This is strange because when I said I just have to set the AcroColor version to 2.
Joe
4. Re: Usage of Acrobat Color layer
lrosenth Dec 14, 2009 3:06 AM (in response to joeln3)There are a few samples in the SDK of using the AC APIs - check them out...
5. Re: Usage of Acrobat Color layer
joeln3 Dec 14, 2009 3:48 AM (in response to lrosenth)Leonard,
I already checked the samples but I think that the problem comes from the environment variable and I'll check what is wrong if you think that it doesn't come from the SDK.
Joe
6. Re: Usage of Acrobat Color layer
lrosenth Dec 14, 2009 3:51 AM (in response to joeln3)It shouldn't come from the SDK - that should be working fine.
