Show 1 reply
1. Re: CS4 3D Question - Can I Remove the Shape from a texture that is mapped
Mylenium Dec 15, 2009 12:10 AM (in response to suzzie12)Conceptually the two are mutually exclusive - can't have textures without geometry. What you need to do instead is add more maps. You need a transparency map to blank out the unwanted parts and then also create specular maps so the transparent areas don't produce highlights. The simple and easy solution would of course be to rasterize the layer and paint out the placeholder face conventionally...
Mylenium
