9 Replies Latest reply on Jan 28, 2010 12:45 AM by tburkeus
    Deploying sample applications in mosaic
    Mário Figueira Newcomer
      Hello, i want to deploy the applications in Mosaic. I'm following these instructions:
      Use the Ant build files provided with the Mosaic ES2 installation to deploy sample applications to the server.
      To run Ant, type ant from the command line. When you do not provide arguments, Ant looks for a build.xml file in the current directory.
      For descriptions of the sample applications, see Sample applications.
      Deploy all samples and demos
      In the following directory, run Ant:
      • [Mosaic ES2 install directory]/samples/
      Deploy the general sample applications
      • [Mosaic ES2 install directory]/samples/general/
      Deploy the MAX2009 application
      • [Mosaic ES2 install directory]/samples/max2009/
      I've set the ant_home enviromment variable but it still gives me the 'ant' is not recognized as an internal or external command,
      operable program or batch file.
      Thanks.
        • 1. Re: Deploying sample applications in mosaic
          I've done it, but now when deploying i have this error.
          BUILD FAILED
          C:\MOSAIC_HOME\samples\general\build.xml:21: Post failed: Connection refused: co
          nnect
          This is communication with server?
          Somebody helps me ?
          Thanks in advance.
          • 2. Re: Deploying sample applications in mosaic
            Hodmi Champion
            Usually this is because the build.xml file is not able to point to the mosaicTasks.jar.
            For example:
            <project name="LiveCycle Mosaic MySamples" default="deploy">
                <taskdef resource="mosaic.tasks" classpath="../bin/mosaicTasks.jar" />
            If the classpath statement in the second line can't find the jar file then it will fail.  The jar file is used to upload catalogs and applications to the mosaic server
            • 3. Re: Deploying sample applications in mosaic
              Hodmi, i've done that but now i got this error:
              C:\MOSAIC_HOME\samples>ant
              Buildfile: build.xml
              deploy:
              deploy-catalogs:
                 [delete] Deleting: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
                    [zip] Building zip: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
              [mosaic-catalog] Exception in thread "Thread-2" C:\MOSAIC_HOME\samples\general\b
              uild.xml:21: Read failed: Server returned HTTP response code: 403 for URL: http:
              //localhost:9080/mosaic/catalogs/sample_catalog
              [mosaic-catalog]        at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask
              .java:413)
              [mosaic-catalog] Caused by: java.io.IOException: Server returned HTTP response c
              ode: 403 for URL: http://localhost:9080/mosaic/catalogs/sample_catalog
              [mosaic-catalog]        at sun.net.www.protocol.http.HttpURLConnection.getInputS
              tream(HttpURLConnection.java:1313)
              .java:407)
              [mosaic-catalog] --- Nested Exception ---
              [mosaic-catalog] java.io.IOException: Server returned HTTP response code: 403 fo
              .java:407)
                   [echo] ${response}
              deploy-applications:
              [mosaic-application] Exception in thread "Thread-4" C:\MOSAIC_HOME\samples\gener
              al\build.xml:33: Read failed: Server returned HTTP response code: 403 for URL: h
              ttp://localhost:9080/mosaic/applications/Basic
              [mosaic-application]    at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask
              .java:413)
              [mosaic-application] Caused by: java.io.IOException: Server returned HTTP respon
              se code: 403 for URL: http://localhost:9080/mosaic/applications/Basic
              [mosaic-application]    at sun.net.www.protocol.http.HttpURLConnection.getInputS
              .java:407)
              [mosaic-application] --- Nested Exception ---
              [mosaic-application] java.io.IOException: Server returned HTTP response code: 40
              .java:407)
                   [echo] ${response}
              [mosaic-application] Exception in thread "Thread-6" C:\MOSAIC_HOME\samples\gener
              al\build.xml:42: Read failed: Server returned HTTP response code: 403 for URL: h
              ttp://localhost:9080/mosaic/applications/Brokerage
              .java:413)
              se code: 403 for URL: http://localhost:9080/mosaic/applications/Brokerage
              .java:407)
              .java:407)
                   [echo] ${response}
              [mosaic-application] Exception in thread "Thread-8" C:\MOSAIC_HOME\samples\gener
              al\build.xml:51: Read failed: Server returned HTTP response code: 403 for URL: h
              ttp://localhost:9080/mosaic/applications/TileGame
              .java:413)
              se code: 403 for URL: http://localhost:9080/mosaic/applications/TileGame
              .java:407)
              .java:407)
                   [echo] ${response}
              [mosaic-application] Exception in thread "Thread-10" C:\MOSAIC_HOME\samples\gene
              ral\build.xml:60: Read failed: Server returned HTTP response code: 403 for URL:
              http://localhost:9080/mosaic/applications/Default
              .java:413)
              se code: 403 for URL: http://localhost:9080/mosaic/applications/Default
              .java:407)
              .java:407)
                   [echo] ${response}
              deploy:
              deploy-catalogs:
                 [delete] Deleting: C:\MOSAIC_HOME\samples\max2009\max2009_catalog.zip
                    [zip] Building zip: C:\MOSAIC_HOME\samples\max2009\max2009_catalog.zip
              [mosaic-catalog] Exception in thread "Thread-12" C:\MOSAIC_HOME\samples\max2009\
              build.xml:21: Read failed: Server returned HTTP response code: 403 for URL: http
              ://localhost:9080/mosaic/catalogs/max2009_catalog
              .java:413)
              ode: 403 for URL: http://localhost:9080/mosaic/catalogs/max2009_catalog
              .java:407)
              .java:407)
                   [echo] ${response}
              [mosaic-application] Exception in thread "Thread-14" C:\MOSAIC_HOME\samples\max2
              009\build.xml:33: Read failed: Server returned HTTP response code: 403 for URL:
              http://localhost:9080/mosaic/applications/MAX2009
              .java:413)
              se code: 403 for URL: http://localhost:9080/mosaic/applications/MAX2009
              .java:407)
              .java:407)
                   [echo] MAX2009 : ${response}
              [mosaic-application] Exception in thread "Thread-16" C:\MOSAIC_HOME\samples\max2
              009\build.xml:42: Read failed: Server returned HTTP response code: 403 for URL:
              http://localhost:9080/mosaic/applications/RedMAX2009
              .java:413)
              se code: 403 for URL: http://localhost:9080/mosaic/applications/RedMAX2009
              .java:407)
              .java:407)
                   [echo] RedMAX2009 : ${response}
              deploy:
              BUILD SUCCESSFUL
              Total time: 7 seconds
              I'm using websphere 6.1.0.2.
              I've got the 403 server in websphere.
              Is there any procedure or any example to workaround this problem in websphere?
              • 4. Re: Deploying sample applications in mosaic
                Hodmi Champion
                humm, interesting.  WebSphere is obviously blocking the file upload.
                Are there other LiveCycle products deployed to that WebSphere instance?
                • 5. Re: Deploying sample applications in mosaic
                  I have the Livecycle deployed there with output es2 and pdf generator.
                  thanks.
                  • 6. Re: Deploying sample applications in mosaic
                    Hodmi Champion
                    Okay, that's good.  It means that the LiveCycle UserManager and Repository components are deployed.
                    The other thing I would check is the username and password sections of the build.xml file.  They will need to be set to a user that has the ROLE_MOSAIC_DESIGNER role in Mosaic.  By default there should be a user called designer with a password of password that has that role.
                    <mosaic-catalog action="import"
                                            name="FADesktop_catalog"
                                            file="FADesktop_catalog.zip"
                                            property="response"
                                            server="${server}"
                                            port="${port}"
                                           username="designer"
                                            password="password"
                            <echo message="${response}" />
                        </target>
                    <mosaic-application action="import"
                                                name="FADesktop"
                                                file="applications/FADesktop.xml"
                                                property="response"
                                                server="${server}"
                                                port="${port}"
                                               username="designer"
                                                password="password"
                    • 7. Re: Deploying sample applications in mosaic
                      I already had it well configured i think, and it's not working. 403 error.
                      <project name="LiveCycle Mosaic Deploy General Samples" default="deploy">
                           <taskdef resource="mosaic.tasks" classpath="C:\MOSAIC_HOME\bin\mosaicTasks.jar" />
                           <property name="protocol" value="http" />
                           <property name="server" value="localhost" />
                           <property name="port" value="9080" />
                          <target name="deploy" depends="deploy-catalogs, deploy-applications" />
                          <target name="deploy-catalogs">
                               <delete file="max2009_catalog.zip" />
                               <zip destfile="max2009_catalog.zip">
                                   <zipfileset dir="catalogs" />
                               </zip>
                                               name="max2009_catalog"
                                               property="response"
                                               server="${server}"
                                               port="${port}"
                                               username="designer"
                                               password="password" />
                           </target>
                          <target name="deploy-applications">
                                                   name="MAX2009"
                                                   file="applications/MAX2009.xml"
                                                   property="response"
                                                   server="${server}"
                                                   port="${port}"
                                                   username="designer"
                               <echo message="MAX2009 : ${response}" />
                                                   name="RedMAX2009"
                                                   file="applications/RedMAX2009.xml"
                                                   property="response"
                                                   server="${server}"
                                                   port="${port}"
                                                   username="designer"
                               <echo message="RedMAX2009 : ${response}" />
                           </target>
                      </project>
                      • 8. Re: Deploying sample applications in mosaic
                        Hodmi Champion
                        Darn, well so much for the easy stuff.
                        There is another spot where the security may have gotten screwed up, but by default this should be okay.  In the mosaic.war file that you deployed to WebSphere is a security.xml file.  (You can open the war file using a zip program.)  the file is located in the WEB-INF directory.
                        This file is where the roles are set for each user (like "designer").  Look for a tag marked security:authentication-provider.  Make sure the "designer" user has the ROLE_MOSAIC_DESIGNER role.  Should look something like:
                        <security:authentication-provider>
                                <security:user-service>
                                    <security:user name="user" password="password" authorities="ROLE_MOSAIC_END_USER"/>
                                    <security:user name="designer" password="password" authorities="ROLE_MOSAIC_END_USER, ROLE_MOSAIC_DESIGNER"/>
                                </security:user-service>
                            </security:authentication-provider>
                        If that is set properly then I can only imagine that its something on the IBM side.  Perhaps additional security has been attached to the mosaic application when the WAR file was deployed.
                        • 9. Re: Deploying sample applications in mosaic
                          tburkeus Newcomer
                          I have the exact same error with JBoss turnkey LC ES2. I've checked the items in the thread and installed according to the instructions to the letter. What likely causes this?
