Hello, i want to deploy the applications in Mosaic. I'm following these instructions:
Use the Ant build files provided with the Mosaic ES2 installation to deploy sample applications to the server.
To run Ant, type ant from the command line. When you do not provide arguments, Ant looks for a build.xml file in the current directory.
For descriptions of the sample applications, see Sample applications.
In the following directory, run Ant:
[Mosaic ES2 install directory]/samples/
Total Likes
I've done it, but now when deploying i have this error.
BUILD FAILED
C:\MOSAIC_HOME\samples\general\build.xml:21: Post failed: Connection refused: co
nnect
This is communication with server?
Somebody helps me ?
Thanks in advance.
Total Likes
Usually this is because the build.xml file is not able to point to the mosaicTasks.jar.
For example:
<project name="LiveCycle Mosaic MySamples" default="deploy">
<taskdef resource="mosaic.tasks" classpath="../bin/mosaicTasks.jar" />
If the classpath statement in the second line can't find the jar file then it will fail. The jar file is used to upload catalogs and applications to the mosaic server
Total Likes
Hodmi, i've done that but now i got this error:
C:\MOSAIC_HOME\samples>ant
Buildfile: build.xml
deploy:
deploy-catalogs:
[delete] Deleting: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
[zip] Building zip: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
[mosaic-catalog] Exception in thread "Thread-2" C:\MOSAIC_HOME\samples\general\b
uild.xml:21: Read failed: Server returned HTTP response code: 403 for URL: http:
//localhost:9080/mosaic/catalogs/sample_catalog
[mosaic-catalog] at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask
.java:413)
[mosaic-catalog] Caused by: java.io.IOException: Server returned HTTP response c
ode: 403 for URL: http://localhost:9080/mosaic/catalogs/sample_catalog
[mosaic-catalog] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1313)[mosaic-catalog] at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask.java:407)[mosaic-catalog] --- Nested Exception ---[mosaic-catalog] java.io.IOException: Server returned HTTP response code: 403 for URL: http://localhost:9080/mosaic/catalogs/sample_catalog[mosaic-catalog] at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1313)[mosaic-catalog] at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask.java:407) [echo] ${response}deploy-applications:
I'm using websphere 6.1.0.2.
I've got the 403 server in websphere.
Is there any procedure or any example to workaround this problem in websphere?
Total Likes
humm, interesting. WebSphere is obviously blocking the file upload.
Are there other LiveCycle products deployed to that WebSphere instance?
Total Likes
I have the Livecycle deployed there with output es2 and pdf generator.
thanks.
Total Likes
Okay, that's good. It means that the LiveCycle UserManager and Repository components are deployed.
The other thing I would check is the username and password sections of the build.xml file. They will need to be set to a user that has the ROLE_MOSAIC_DESIGNER role in Mosaic. By default there should be a user called designer with a password of password that has that role.
<mosaic-catalog action="import"
name="FADesktop_catalog"
file="FADesktop_catalog.zip"
property="response"
server="${server}"
port="${port}"
username="designer"
password="password" />
<echo message="${response}" />
</target>
<mosaic-application action="import"
name="FADesktop"
file="applications/FADesktop.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
Total Likes
I already had it well configured i think, and it's not working. 403 error.
<project name="LiveCycle Mosaic Deploy General Samples" default="deploy">
<taskdef resource="mosaic.tasks" classpath="C:\MOSAIC_HOME\bin\mosaicTasks.jar" />
<property name="protocol" value="http" />
<property name="server" value="localhost" />
<property name="port" value="9080" />
<target name="deploy" depends="deploy-catalogs, deploy-applications" />
<target name="deploy-catalogs">
<delete file="max2009_catalog.zip" />
<zip destfile="max2009_catalog.zip">
<zipfileset dir="catalogs" />
</zip>
name="max2009_catalog"
property="response"
server="${server}"
port="${port}"
username="designer"
</target>
<target name="deploy-applications">
name="MAX2009"
file="applications/MAX2009.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
<echo message="MAX2009 : ${response}" />
name="RedMAX2009"
file="applications/RedMAX2009.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
<echo message="RedMAX2009 : ${response}" />
</target>
</project>
Total Likes
Darn, well so much for the easy stuff.
There is another spot where the security may have gotten screwed up, but by default this should be okay. In the mosaic.war file that you deployed to WebSphere is a security.xml file. (You can open the war file using a zip program.) the file is located in the WEB-INF directory.
This file is where the roles are set for each user (like "designer"). Look for a tag marked security:authentication-provider. Make sure the "designer" user has the ROLE_MOSAIC_DESIGNER role. Should look something like:
<security:authentication-provider>
<security:user-service>
<security:user name="user" password="password" authorities="ROLE_MOSAIC_END_USER"/>
<security:user name="designer" password="password" authorities="ROLE_MOSAIC_END_USER, ROLE_MOSAIC_DESIGNER"/>
</security:user-service>
</security:authentication-provider>
If that is set properly then I can only imagine that its something on the IBM side. Perhaps additional security has been attached to the mosaic application when the WAR file was deployed.
Total Likes
I have the exact same error with JBoss turnkey LC ES2. I've checked the items in the thread and installed according to the instructions to the letter. What likely causes this?
Total Likes
