1. Re: Deploying sample applications in mosaic
Mário Figueira Dec 16, 2009 12:13 PM (in response to Mário Figueira)I've done it, but now when deploying i have this error.
BUILD FAILED
C:\MOSAIC_HOME\samples\general\build.xml:21: Post failed: Connection refused: co
nnectThis is communication with server?
Somebody helps me ?
Thanks in advance.
2. Re: Deploying sample applications in mosaic
HodmiDec 16, 2009 1:05 PM (in response to Mário Figueira)
Usually this is because the build.xml file is not able to point to the mosaicTasks.jar.
For example:
<project name="LiveCycle Mosaic MySamples" default="deploy">
<taskdef resource="mosaic.tasks" classpath="../bin/mosaicTasks.jar" />....
If the classpath statement in the second line can't find the jar file then it will fail. The jar file is used to upload catalogs and applications to the mosaic server
3. Re: Deploying sample applications in mosaic
Mário Figueira Dec 17, 2009 4:35 AM (in response to Hodmi)Hodmi, i've done that but now i got this error:
C:\MOSAIC_HOME\samples>ant
Buildfile: build.xml
deploy:
deploy-catalogs:
[delete] Deleting: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
[zip] Building zip: C:\MOSAIC_HOME\samples\general\sample_catalog.zip
[mosaic-catalog] Exception in thread "Thread-2" C:\MOSAIC_HOME\samples\general\b
uild.xml:21: Read failed: Server returned HTTP response code: 403 for URL: http:
//localhost:9080/mosaic/catalogs/sample_catalog
[mosaic-catalog] at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask
.java:413)
[mosaic-catalog] Caused by: java.io.IOException: Server returned HTTP response c
ode: 403 for URL: http://localhost:9080/mosaic/catalogs/sample_catalog
deploy-applications:
[mosaic-application] Exception in thread "Thread-4" C:\MOSAIC_HOME\samples\gener
al\build.xml:33: Read failed: Server returned HTTP response code: 403 for URL: h
ttp://localhost:9080/mosaic/applications/Basic
[mosaic-application] at com.adobe.mosaic.ant.MosaicTask$Reader.run(MosaicTask
.java:413)
[mosaic-application] Caused by: java.io.IOException: Server returned HTTP respon
se code: 403 for URL: http://localhost:9080/mosaic/applications/Basic
[mosaic-application] at sun.net.www.protocol.http.HttpURLConnection.getInputS
tream(HttpURLConnection.java:1313)
.java:407)
[mosaic-application] --- Nested Exception ---
[mosaic-application] java.io.IOException: Server returned HTTP response code: 40
.java:407)
[echo] ${response}
[mosaic-application] Exception in thread "Thread-6" C:\MOSAIC_HOME\samples\gener
al\build.xml:42: Read failed: Server returned HTTP response code: 403 for URL: h
ttp://localhost:9080/mosaic/applications/Brokerage
.java:413)
se code: 403 for URL: http://localhost:9080/mosaic/applications/Brokerage
.java:407)
.java:407)
[echo] ${response}
[mosaic-application] Exception in thread "Thread-8" C:\MOSAIC_HOME\samples\gener
al\build.xml:51: Read failed: Server returned HTTP response code: 403 for URL: h
ttp://localhost:9080/mosaic/applications/TileGame
.java:413)
se code: 403 for URL: http://localhost:9080/mosaic/applications/TileGame
.java:407)
.java:407)
[echo] ${response}
[mosaic-application] Exception in thread "Thread-10" C:\MOSAIC_HOME\samples\gene
ral\build.xml:60: Read failed: Server returned HTTP response code: 403 for URL:
http://localhost:9080/mosaic/applications/Default
.java:413)
se code: 403 for URL: http://localhost:9080/mosaic/applications/Default
.java:407)
.java:407)
[echo] ${response}
[delete] Deleting: C:\MOSAIC_HOME\samples\max2009\max2009_catalog.zip
[zip] Building zip: C:\MOSAIC_HOME\samples\max2009\max2009_catalog.zip
[mosaic-catalog] Exception in thread "Thread-12" C:\MOSAIC_HOME\samples\max2009\
build.xml:21: Read failed: Server returned HTTP response code: 403 for URL: http
://localhost:9080/mosaic/catalogs/max2009_catalog
.java:413)
ode: 403 for URL: http://localhost:9080/mosaic/catalogs/max2009_catalog
[mosaic-catalog] at sun.net.www.protocol.http.HttpURLConnection.getInputS
.java:407)
[mosaic-catalog] --- Nested Exception ---
[mosaic-catalog] java.io.IOException: Server returned HTTP response code: 403 fo
.java:407)
[echo] ${response}
[mosaic-application] Exception in thread "Thread-14" C:\MOSAIC_HOME\samples\max2
009\build.xml:33: Read failed: Server returned HTTP response code: 403 for URL:
http://localhost:9080/mosaic/applications/MAX2009
.java:413)
se code: 403 for URL: http://localhost:9080/mosaic/applications/MAX2009
.java:407)
.java:407)
[echo] MAX2009 : ${response}
[mosaic-application] Exception in thread "Thread-16" C:\MOSAIC_HOME\samples\max2
009\build.xml:42: Read failed: Server returned HTTP response code: 403 for URL:
http://localhost:9080/mosaic/applications/RedMAX2009
.java:413)
se code: 403 for URL: http://localhost:9080/mosaic/applications/RedMAX2009
.java:407)
.java:407)
[echo] RedMAX2009 : ${response}
Total time: 7 seconds
C:\MOSAIC_HOME\samples>I'm using websphere 6.1.0.2.
I've got the 403 server in websphere.
Is there any procedure or any example to workaround this problem in websphere?
4. Re: Deploying sample applications in mosaic
HodmiDec 17, 2009 7:36 AM (in response to Mário Figueira)
humm, interesting. WebSphere is obviously blocking the file upload.
Are there other LiveCycle products deployed to that WebSphere instance?
5. Re: Deploying sample applications in mosaic
Mário Figueira Dec 17, 2009 7:39 AM (in response to Hodmi)I have the Livecycle deployed there with output es2 and pdf generator.
thanks.
6. Re: Deploying sample applications in mosaic
HodmiDec 17, 2009 8:24 AM (in response to Mário Figueira)
Okay, that's good. It means that the LiveCycle UserManager and Repository components are deployed.
The other thing I would check is the username and password sections of the build.xml file. They will need to be set to a user that has the ROLE_MOSAIC_DESIGNER role in Mosaic. By default there should be a user called designer with a password of password that has that role.
<mosaic-catalog action="import"
name="FADesktop_catalog"
file="FADesktop_catalog.zip"
property="response"
server="${server}"
port="${port}"
username="designer"
password="password" />
<echo message="${response}" />
</target>....
<mosaic-application action="import"
name="FADesktop"
file="applications/FADesktop.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
<echo message="${response}" />....
7. Re: Deploying sample applications in mosaic
Mário Figueira Dec 17, 2009 9:05 AM (in response to Hodmi)I already had it well configured i think, and it's not working. 403 error.
<project name="LiveCycle Mosaic Deploy General Samples" default="deploy">
<taskdef resource="mosaic.tasks" classpath="C:\MOSAIC_HOME\bin\mosaicTasks.jar" />
<property name="protocol" value="http" />
<property name="server" value="localhost" />
<property name="port" value="9080" /><target name="deploy" depends="deploy-catalogs, deploy-applications" />
<target name="deploy-catalogs">
<delete file="max2009_catalog.zip" />
<zip destfile="max2009_catalog.zip">
<zipfileset dir="catalogs" />
</zip>
name="max2009_catalog"
property="response"
server="${server}"
port="${port}"
username="designer"
</target><target name="deploy-applications">
name="MAX2009"
file="applications/MAX2009.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
<echo message="MAX2009 : ${response}" />
name="RedMAX2009"
file="applications/RedMAX2009.xml"
property="response"
server="${server}"
port="${port}"
username="designer"
<echo message="RedMAX2009 : ${response}" />
</target></project>
8. Re: Deploying sample applications in mosaic
HodmiDec 18, 2009 5:25 AM (in response to Mário Figueira)
Darn, well so much for the easy stuff.
There is another spot where the security may have gotten screwed up, but by default this should be okay. In the mosaic.war file that you deployed to WebSphere is a security.xml file. (You can open the war file using a zip program.) the file is located in the WEB-INF directory.
This file is where the roles are set for each user (like "designer"). Look for a tag marked security:authentication-provider. Make sure the "designer" user has the ROLE_MOSAIC_DESIGNER role. Should look something like:
<security:authentication-provider>
<security:user-service>
<security:user name="user" password="password" authorities="ROLE_MOSAIC_END_USER"/>
<security:user name="designer" password="password" authorities="ROLE_MOSAIC_END_USER, ROLE_MOSAIC_DESIGNER"/>
</security:user-service>
</security:authentication-provider>If that is set properly then I can only imagine that its something on the IBM side. Perhaps additional security has been attached to the mosaic application when the WAR file was deployed.
9. Re: Deploying sample applications in mosaic
tburkeusJan 28, 2010 12:45 AM (in response to Hodmi)
I have the exact same error with JBoss turnkey LC ES2. I've checked the items in the thread and installed according to the instructions to the letter. What likely causes this?
