Will I still be able to use my existing cfc, cfm, and folders if I upgrade to CF Builder Beta 3?
If you use the same workspace you had created with earlier build, then all projects will autmatically be avilable with the new build.
However we reccomend to use a new workspace with every beta build. In that case you could import existing CF projects by selecting option - File->Import->ColdFusion->'Import Existing Projects'.
-Ram
When I have done that in the past sometimes I cannot get the imported project to open correctly unless I also keep the existing project in its different workspace. This uses up too much space. What could I do better/easier?
Can you be more specific about what problems you had when you imported projects? Also, it is not necessary to create projects in
the worspace. You can have them outside and shared amoungst
different workspaces.
-Ram
