I have some code where I'm uploading different file types to my server. This works great. However, I'm trying to upload the file name to the MySQL database but I can't seem to get it to go. Any help on this would be greatly appreciated. Thanks.
My Code:
<CFSET FileDir = ExpandPath("..\manage\users\#acct#\#fileLoc#\")>
<cffile action="upload" destination="#FileDir#" filefield="fileUPLOAD" nameconflict="overwrite" result="Upload">
<cffile ACTION="Read" FILE="#FileDir#" variable="FileData">
<cfquery name="UploadFile" datasource="#db#">
INSERT INTO documents (User_ID, title, file_name)
VALUES (#FORM.UserID#, '#FORM.title#', <cfqueryparam cfsqltype="cf_sql_varchar" value="#FileData#"> )
</cfquery>
You say you want to store the file name, but your code shows you trying to store the contents. The file name gets generated during the upload process. Cfdump your upload variable and see if it contains anything useful.
I don't see anything, just outputs a the name of the field. I don't have anything useful on this.
I am trying to capture the filename and I have a seperate field where they type in a better name for the file they are uploading.
<cfdump var="#Upload#">
This doesn't show you anything interesting?
I get an error everytime...
Variable UPLOAD is undefined.
What about the older
<cfdump var="#cffile#">
Your <cfffile....> tag does have the result="Upload" paramter correct?
Okay, so I did a dump on <CFFILE
This is what I get....
An error occurred when performing a file operation read on file E:\WEB\bkllp\manage\users\kanner\Ray-z173n7d\.
This is the proper file location folder.
Are you doing these dumps after the <cffile action="upload"...> OR after the <cffile action="read"...> My suggestion was to put it after the former not the latter.
This is what I have...
<cffile action="upload" destination="#FileDir#" filefield="fileUPLOAD" nameconflict="overwrite" result="UploadFile">
<cfquery name="UploadFile" datasource="kanner">
</cfquery>
Try this:
<cfdump var="#cffile#"><cfabort>
</cfquery>
It is the <cffil action="read"...> line that is throwing that previous error, because you are just passing it a directory, not a directory with a file name.
But then, I'm hopping to show you how you do not need the <cffile action="read"...> line.
well, this is what I got...
struct [empty]
would really like to know an easier way to accomplish my goal here. thanks for your help on this.
struct [empty]
Then something is wrong, because this normally IS easy, and that structure should have plenty of information to make this simple.
You are sure you are properly uploading the desired files?
The file Upload works just perfectly.
<cfquery name="GetName" datasource="kanner">
Select file, accountant, FirstName, LastName, Email
From users
WHERE User_ID = #Form.UserID#
</cfquery>
<cfset acct = #GetName.accountant#>
<cfset fileLoc = #GetName.file#>
Then the client wanted to add a "Title" to the file. Make it easier for thier users to know what they are downloading. So I add a text field called "title" on the file upload page. So, in order for the File and the Title to correspond I thought I should upload the file name and title into the database. So I added this code to do that.
VALUES (#FORM.UserID#, '#FORM.title#', <cfqueryparam cfsqltype="cf_sql_varchar" value="#FileData#"> ) </cfquery>
So when the user logs into view the available files to download they would see their directory listing along with the "TItle". and I used the following code to display available file downloads.
<cfparam name="url.sort" default="datelastmodified desc">
<cfdirectory directory="#ExpandPath("./users/#GetName.accountant#/#GetName.file#")#" action="list" name="dir" sort="#url.sort#">
This is the whole picture of what I'm trying to accomplish.
If you do this:
<cfdump var="#UploadFile#">
<cfabort>
and you see an empty structure, something went wrong.
Later, there are two problems with this:
The first problem is that FileDir is a directory path and does not contain the name of the file. This should cause your cffile tag to fail. The second is that once you successfully read the file, the FileData variable will not contain the name of the file, it will contain the contents.
I was doing the dump wrong. Here are my results.
struct | |
ATTEMPTEDSERVERFILE | CF-uploading.pdf |
CLIENTDIRECTORY | CF-uploading.pdf |
CLIENTFILE | CF-uploading.pdf |
CLIENTFILEEXT | |
CLIENTFILENAME | CF-uploading |
CONTENTSUBTYPE | |
CONTENTTYPE | application |
DATELASTACCESSED | {d '2009-12-15'} |
FILEEXISTED | YES |
FILESIZE | 389107 |
FILEWASAPPENDED | NO |
FILEWASOVERWRITTEN | YES |
FILEWASRENAMED | NO |
FILEWASSAVED | YES |
OLDFILESIZE | 389107 |
SERVERDIRECTORY | E:\WEB\bkllp\manage\users\kanner\Courtney-Ray-z173n7d |
SERVERFILEEXT | |
SERVERFILENAME | CF-uploading |
TIMECREATED | {ts '2009-12-15 14:48:08'} |
TIMELASTMODIFIED | {ts '2009-12-15 14:48:08'} |
So, how do I insert the name of the file into the database? Would I use ClientFile?
I would suspect serverfile is more relevant. That is the name of the file on your server as apposed to the name that the file was on the
client. Those are not always the same.
okay, but how do I reference it my query?
I tried this and received an error.
VALUES (#FORM.UserID#, '#FORM.title#', <cfqueryparam cfsqltype="cf_sql_varchar" value="#UploadFile.SERVERFILE#"> ) </cfquery>
I also tried.
VALUES (#FORM.UserID#, '#FORM.title#', <cfqueryparam cfsqltype="cf_sql_varchar" value="#CFFILE.SERVERFILE#"> ) </cfquery>
Do I still need to use this line? I just need to store the name of the file, not the data. I had this commented out during the previous queries. Didn't think I needed this line.
Looks like you are overwriting your UploadFile variable. You use it in your cffile action = upload tag, and then again as the name of your query. That is probably causing your problem.
Do you still need to read the file? Not if all you want to do is store the name in your db.
Thank you. I have figured it out and it works like a champ. I'm posting the final code in case someone else needs it.
<cfset FileNameUpload = #UploadFile.serverfile#>
<cfset UserIDUpload = #Form.UserID#>
<cfset FileTitle = #Form.title#>
<cfquery name="DoUpload" datasource="#DS#">
VALUES ('#UserIDUpload#', '#FileTitle#', '#FileNameUpload#')
</cfquery>
