X5.02, WebHelp project
Error message: "Publishing has been cancelled. There is not enough space on the disk." The RoboHelp project is stored on my desktop. What do I need to check or do? The project is stored on my desktop. Although this error message appears, the project IS being published, but without a Table of Contents (TOC). They may be two unrelated issues, but does anyone have any insight into either issue?
Thank you
The first question is how much free space is there?
Assuming plenty, try publishing to a different folder.
When you view the help locally, are you using IE and does the yellow information bar appear? If it does, are you allowing Active X to run?
Follow me @petergrainge
Thanks Peter. It's working now, but can you help me understand what caused the problem? Prior to my post I had deleted the original folder, published, & experienced the same error. How does publishing to a new folder correct the issue? Thanks
It's an old problem that nobody has really cracked. The best theory is the elves are involved somewhere along the line.
