Regular Expression - find double hyphens only
Guest
Dec 22, 2009 Dec 22, 2009
I am wondering if there's a way to write a regular expression to find double hyphens and change them to single hyphens.  The catch is that some of the text I'm searching through have multiple hyphens.
Example:
str1 = "Here is my sample text with double -- and I would like to replace this with one hyphen."
str2 = "Here is another sample with multiple hyphens ----- that I do not want to change but leave as is."
Is there a way to change only str1 to a single hyphen and keep str2 as is?
Advanced techniques
3.4K
It sounds to me that it's not "double hyphens" you want to replace, but it's space+hyphen+hyphen+space?  Or not-hyphen+hyphen+hyphen+not-hyphen?
The former does not need a regex.  The second is definitely doable with a regex, yes: give it a go working it out for yourself, and report back with results/problems...
Adam
Guest
You are correct.  I should have been more explict.  Here are some real examples.  I hope this helps.
"MS3367--1--9"            This needs to be changed to "MS3367-1-9"
"AN/ALQ--218"            This needs to be changed to "AN/ALQ-218"
"Dashes (-----) will"       This does not need to be changed.
Helps what?
Have you tried to write the regex yourself, at least?
Adam
Guest
I figured it out.  The answer is ([A-Za-z0-9]--[A-Za-z0-9])|(\s--\s).
Documentation
