Captivate F1 online help in tiny text too small to read
Aug 20, 2008 Aug 20, 2008
Having downloaded a Trial version of the Adobe Technical Communications Suite I found this problem affects all the components in one way or another.
In Captivate, the The Table of Contents pane displays fine, but the topic content is painfully small and hence illegible.
FrameMaker online help is the same but and although the tiny text looks very fuzzy I can just about guess at the words.
The same issue affects Adobe Reader 8 help files.
RoboHelp for HTML has the opposite problem - the topic text is perfectly legible but the Table of Contents list in the left-hand pane is very small and a bit of a struggle to read.
Has anyone come across this and found the solution?
Getting started
694
Welcome to our community, Cecelia
Help normally displays using Browser components. If you have a mouse with a wheel in the center, perhaps click in the area where the tiny text appears, then press and hold the Control key on your keyboard while you rotate the wheel to make the text larger or smaller. You may also wish to try using Control key along with the Plus ( + ) or Minus ( - ) keys to adjust the text.
Hopefully this was helpful in some way... Rick
Thanks Rick! We tried that but no joy (this problem has got my colleagues all beat too)
Ouch! Yes I just realized that. Hmmm, sorry but about the only thing I might suggest would be to obtain a screen magnifier application for it. Either that or select all the text and paste it into an instance of Notepad or Word, where you may adjust the font to be larger.
You should also consider reporting this as a bug to the development team.
Click here to view the WishForm/Bug Reporting Form
Cheers... Rick
Aug 26, 2008 Aug 26, 2008
Rick, that's a great workaround! And thank you for the link to the bug report site too. Cheers, C.
Help resources
