Hi there, having the following pblm. Using pmd 1.0 (latest available version, archived named 1.0.1 something)
BUILD FAILED
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1938)
at com.adobe.ac.pmd.nodes.impl.MetaDataNode.compute(MetaDataNode.java:54)
at com.adobe.ac.pmd.nodes.impl.NodeFactory.createMetaData(NodeFactory.java:41)
at com.adobe.ac.pmd.nodes.utils.MetaDataUtils.computeMetaDataList(MetaDataUtils.java:46)
at com.adobe.ac.pmd.nodes.impl.FunctionNode.compute(FunctionNode.java:120)
at com.adobe.ac.pmd.nodes.impl.ClassNode.detectFunction(ClassNode.java:306)
at com.adobe.ac.pmd.nodes.impl.ClassNode.computeClassContent(ClassNode.java:262)
at com.adobe.ac.pmd.nodes.impl.ClassNode.compute(ClassNode.java:103)
at com.adobe.ac.pmd.nodes.impl.PackageNode.compute(PackageNode.java:73)
at com.adobe.ac.pmd.nodes.impl.NodeFactory.createPackage(NodeFactory.java:46)
at com.adobe.ac.pmd.files.FileSetUtils.computeAsts(FileSetUtils.java:101)
at com.adobe.ac.pmd.FlexPmdViolations.computeAsts(FlexPmdViolations.java:118)
at com.adobe.ac.pmd.FlexPmdViolations.computeViolations(FlexPmdViolations.java:96)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.computeViolations(AbstractFlexPmdEngine.java:156)
at com.adobe.ac.pmd.engines.AbstractFlexPmdEngine.executeReport(AbstractFlexPmdEngine.java:138)
at com.adobe.ac.pmd.ant.FlexPmdAntTask.execute(FlexPmdAntTask.java:64)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1189)
at org.apache.tools.ant.Main.runBuild(Main.java:758)
at org.apache.tools.ant.Main.startAnt(Main.java:217)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
Total time: 0 seconds
could you advise what can be the problem?
I commented on this issue: http://bugs.adobe.com/jira/browse/FLEXPMD-140
It should be working.
Let me know.
Xavier
Thanks for the post.
This JIRA link needs some signup. When I am trying to sign up, it does not send me activation to the email (tried 2 different e-mails) Do not know, if it is because of holidays. Could you post this solution here?
Thanks for help, the first problem was removed, however I have another one (after start using attached file)
BUILD FAILED
java.lang.NoSuchMethodError: com.adobe.ac.pmd.files.impl.FileUtils.computeFilesList(Ljava/io/File;Ljava/lang/String;)Ljava/util/Ma
p;
at com.adobe.ac.pmd.FlexPmdViolations.computeFiles(FlexPmdViolations.java:131)
at com.adobe.ac.pmd.FlexPmdViolations.computeViolations(FlexPmdViolations.java:94)
Please, use that file:
http://opensource.adobe.com/svn/opensource/flexpmd/maven-repository/snapshot/com/adobe/ac/flex-pmd-core/1.1-SNAPSHOT/flex-pmd-core-1.1-20091229.030128-3.jar
Xavier
