When I turned on my desktop tonight, there was a pop-up from Adobe about downloading a new (update) download for Adobe Flash Player. I've seen these before and always clicked on them.
After the download I had to go to SpeedTest site and when I went to the site, it mentioned that I needed at least Flash Player 8 to run the program (I knew I had Flash Player 10 installed). I've always been going to this SpeedTest page before with no problems. I remembered I just downloaded the new update for the Flash Player and I went into my Resotre Point, which was done (luckily) this afternoon. I restored my system and when I went back to the SpeedTest page, I was able to run the speed test.
Would anyone know what might have happened?
(BTW - #1- If I ever wanted to uninstall Flash Player, how would that be done? I don't see it in Add/Remove programs. #2- Is there a way to send a support/technical question to Adobe re: Flash Player?)
Flash Player (Plugin or ActiveX) should show on Add/Remove Programs; I don't know why it doesn't on your system.
To uninstall it anyway, you can use the uninstaller from http://kb2.adobe.com/cps/141/tn_14157.html; make sure that all browser windows are closed when you run the uninstaller.
