I installed CFBuilder Beta 3 on a Windows XP SP3 machine in the standalone configuration from the Administrator account. At the end of the installation I choose not to start CFBuilder, but instead started it manually from my own user account (Power User group) on the system. The startup consistently gave an error. Removed CFBuilder, installed it again, same problem.
Then I used the "runas" command to start CFBuilder as Administrator. CFBuilder started up correctly. Closed it, started CFBuilder from my own account. This time no error, but instead I was prompted to select a different workspace since the workspace was in use. After selecting a different workspace everything is fine now.
Logfile from a startup error attached.
Hi Jochem,
When you started CFB did the error come up as a pop-up message? If yes, what was the error message?
From the logs this doesn't really seem to be an issue because CFB was not started with 'Run as Administrator' option.
We will have a detailed look into the logs and get back.
Bhakti
Bhakti Pingale wrote on 12/31/2009 7:56 AM:
It said something like "The bundle could not be resolved." and pointed
to the log file.
I agree, usually when you have insufficient permissions you get a some
io.SecurityException in the log, but this one is a bit weird.
I don't think that all that many CF developers log in with a
non-administrator account, so this may be a code path that gets
exercised less frequently. I'll see if it is reproducible when I do a
few more uninstall / install cycles this weekend.
Thanks Jochem.
We will try the same at our end.
-Bhakti
It is a permissions issue that is fixable by assigning additional
permissions to the user. For now I have upgraded the Power Users group
to Change permissions.
Before:
C:\Program Files\Adobe>cacls "Adobe ColdFusion Builder"
C:\Program Files\Adobe\Adobe ColdFusion Builder BUILTIN\Users:R
BUILTIN\Users:(OI)(CI)(IO)(special access:)
GENERIC_READ
GENERIC_EXECUTE
BUILTIN\Power Users:C
BUILTIN\Power Users:(OI)(CI)(IO)C
BUILTIN\Administrators:F
BUILTIN\Administrators:(OI)(CI)(IO)F
NT AUTHORITY\SYSTEM:F
NT AUTHORITY\SYSTEM:(OI)(CI)(IO)F
PRLT-J002\Administrator:F
CREATOR OWNER:(OI)(CI)(IO)F
After:
GENERIC_READ
GENERIC_EXECUTE
BUILTIN\Power Users:(OI)(CI)(IO)(special access:)
DELETE
READ_CONTROL
SYNCHRONIZE
GENERIC_READ
GENERIC_WRITE
GENERIC_EXECUTE
FILE_GENERIC_READ
FILE_GENERIC_WRITE
FILE_GENERIC_EXECUTE
FILE_READ_DATA
FILE_WRITE_DATA
FILE_APPEND_DATA
FILE_READ_EA
FILE_WRITE_EA
FILE_EXECUTE
FILE_READ_ATTRIBUTES
FILE_WRITE_ATTRIBUTES
With this change CFBuilder starts correctly.
Jochem
