1. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
pziecina Dec 31, 2009 7:43 AM (in response to thanser)Hi
Can you provide a link to a live site?
Check the variables being used by the behaviors are not the same, (i.e. one behavior is not changing the others variable for the button).
PZ
2. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
thanser Dec 31, 2009 10:23 AM (in response to pziecina)Page code is attached to original post - no images, sorry.
I can post this page tonight but I'm at work for a while.
3. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
pziecina Dec 31, 2009 10:35 AM (in response to thanser)Hi
The attached file is a zip file, and I like many others will not download a zip file unless there is no alternative.
PZ
4. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
thanser Dec 31, 2009 11:09 AM (in response to pziecina)Page code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>index</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /><script type="text/javascript">
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
}function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
}function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
}function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<style type="text/css">
body {
background-image: url(images/screens_back.gif);
</style></head>
<body bgcolor="#FFFFFF" onLoad="MM_preloadImages('images/navigation_2_over-05.gif','images/navigation_2_over-06.g if','images/navigation_2_over-07.gif','images/navigation_over-08.gif','images/navigation_o ver-09.gif','images/navigation_over-10.gif','images/team.gif','images/forms.gif','images/e xport.gif','images/consulting.gif','images/programming.gif','images/contact.gif')"><table width="792" border="0" align="center" cellpadding="0" cellspacing="0" id="Table_01">
<tr>
<td width="792" height="126" colspan="2">
<img id="index" src="images/index.gif" width="792" height="126" alt="" /></td>
</tr>
<tr>
<td width="792" height="34" colspan="2">
<table id="Table_01" width="792" height="34" border="0" cellpadding="0" cellspacing="0">
<tr>
<td width="34" height="34">
<img src="images\navigation_2.gif" width="34" height="34" alt="" /></td>
<td width="426" height="34">
<img src="images\navigation_2-02.gif" width="426" height="34" alt="" /></td>
<td width="105" height="34" id="title">
<img src="images\blank.gif" alt="" name="blank" width="105" height="34" id="blank" /></td>
<td width="5" height="34">
<img src="images\navigation_2-04.gif" width="5" height="34" alt="" /></td>
<td width="36" height="34">
<img src="images\navigation_2-05.gif" alt="" width="36" height="34" id="Image1" onMouseOver="MM_swapImage('Image1','','images/navigation_2_over-05.gif',1);MM_swapImage(' blank','','images/team.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<td width="32" height="34">
<img src="images\navigation_2-06.gif" alt="" width="32" height="34" id="Image2" onMouseOver="MM_swapImage('Image2','','images/navigation_2_over-06.gif',1);MM_swapImage(' blank','','images/forms.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<td width="31" height="34">
<img src="images\navigation_2-07.gif" alt="" width="31" height="34" id="Image3" onMouseOver="MM_swapImage('Image3','','images/navigation_2_over-07.gif',1);MM_swapImage(' blank','','images/export.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<td width="33" height="34">
<img src="images\navigation_2-08.gif" alt="" width="33" height="34" id="Image4" onMouseOver="MM_swapImage('Image4','','images/navigation_over-08.gif',1);MM_swapImage('bl ank','','images/consulting.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<img src="images\navigation_2-09.gif" alt="" width="31" height="34" id="Image5" onMouseOver="MM_swapImage('Image5','','images/navigation_over-09.gif',1);MM_swapImage('bl ank','','images/programming.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<td width="42" height="34">
<img src="images\navigation_2-10.gif" alt="" width="42" height="34" id="Image6" onMouseOver="MM_swapImage('Image6','','images/navigation_over-10.gif',1);MM_swapImage('bl ank','','images/contact.gif',1)" onMouseOut="MM_swapImgRestore()" /></td>
<td width="17" height="34">
<img src="images\navigation_2-11.gif" width="17" height="34" alt="" /></td>
</tr>
</table>td>
</tr>
<tr>
<td width="410" height="352">
<img id="index003" src="images/index-03.gif" width="410" height="352" alt="" /></td>
<td width="382" height="352">
<img id="index004" src="images/index-04.gif" width="382" height="352" alt="" /></td>
</tr>
<tr>
<td width="792" height="29" colspan="2">
<img id="index005" src="images/index-05.gif" width="792" height="29" alt="" /></td>
</tr>
</table>
</body>
</html>I can't publish the page and images until later tonight.
Thanks, as always.
5. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
pziecina Dec 31, 2009 11:29 AM (in response to thanser)Hi
A quick look at the code does point to the variables used (or not), causing a conflict.
The simple solution would be to use pure css for the disjointed behavior that you are using.
See - http://bonrouge.com/br.php?page=disjointed1.
or http://alt-web.com/DEMOS/CSS-Disjointed-Menu-Rollover.shtml
The second link is from Nancy's site (a respected contributor to this forum), and is the one I would recommend.
PZ
6. Re: Two Swap Image Behaviors - Only One Swap Image Restore Works
thanser Dec 31, 2009 11:46 AM (in response to pziecina)Great, thank you. I'll try one of these recomendations tonight.
I wasn't sure if I could apply two behaviors on the same link/image and obviously it won't work.
Thanks again.
