Good Day;
I have been asked to design a form using Livecycle that will replace an existing MS Word form. The form will be used to grant access to a total of 42 information systems.
At first glance this did not seem to be a problem until I stated to design the layout. For the most part the form is more or less straight forward. Where I ran into design problems was with the best way to have the user fill in what systems they were requesting. A user could request anywhere from 1 to 42 of the information systems.
The initial design had all 42 systems listed with option required. This, (I thought) was way to long.
Example: These field are inside a table.
System Name | Requested View | Domain Requested
AAAAA -AAAAAAAA | Select 1 or all of 5| Select 1 or all of 3
What I would like to do is create this part of the form as a “as required”. The way I envision this working is to have a dropdown for the first system and then the user can request request another entry (using a button etc..), a blank row would come up and from a drop down they would be able to pick the system name and then be able to select the Request View and Domain Requested. I hope I have explained this well enough
Does anyone know if this is possible?
Chomp
Solved! Go to Solution.
Total Likes
Here is a sample for you of what I think you want. Note that if you select the system from a DDList then there are lots of things to check ...I dud a few in the code so it can get a little complicated.
Paul
Total Likes
Paul
Total Likes
Thank you very much Paul. This gets me pointed in the right direction. Now I just need to put the
full form together.
Thanks Again
Chomp
Total Likes
