I know this was an old question, but mine is the same, with a twist. I see that you say Captivate doesn't support keyboard control in the playback skin by default. But would it be workable to create a custom Flash skin that does look for and operate with keyboard commands? In particular, it would be great to enable a user to hit the forward arrow button as an option rather than clicking with the mouse. Is this feasible, or would it be a waste of time to develop?
Thanks.
Hi there
Not being a Flash programmer I cannot say how simple it might be to achieve. I might think that if you are totally familiar with Flash it would be a fairly simple task. Then again, the workaround I proposed is simple too and would take less than two minutes to achieve.
Your call... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
I agree that your solution is simple and it works, but it's a bit messy in that we'd have to add these boxes to all slides. If only click boxes had the "Display for rest of project" option.
I need to learn Flash soon anyway, and I agree that this doesn't sounds like a difficult Flash problem, so I am going to head in that direction.
Thanks.
Hi again
Yes it seems messy at first. But hopefully you realize you can configure and place only one of the little beasties, then copy it. Select all the remaining slides in the Filmstrip or in Storyboard view, then paste in a single action.
Please don't let that dissuade you in any way from learning Flash. I've got it on my own radar to learn as well. Perhaps my third attempt will finally be the magick one that sticks and finally makes it make sense. I must be thick headed. Then again, during the second Flash class the instructor started off by saying "Flash is probably *THE* most unintuitive application you will ever try to learn."
Cheers... Rick
Rick,
You make an excellent point, and I had forgotten about the copy to multiple slides. It's better, but still not as elegant as I'd like.
I'm hopeful to pick up Flash although, like you, I have tried twice in the past and it hasn't sunk in. Maybe this time will be the charm.
Thanks.
