In an htm file I've had some success linking to the ROBOHELP_CSH.JS file with either of these methods;
1) locally
<script type="text/javascript" language=JavaScript1.2 src="RoboHelp_CSH.js"></script>
or
2) at some url
<script type="text/javascript" language=JavaScript1.2 src="http://www.ourdomain.com/members/secure/productname/help/webhelp/ROBOHELP_CSH.JS"></script>
But I get different behavious, I can lose my context, when I change the way I access the startpage.htm. Can any of you help me understand why this is? Thank you.
When I use this kind of link to a local startpage, context map works and I see my topic.
<p><A HREF='javascript:RH_ShowHelp(0,"prcdhelp.htm>NPC", HH_HELP_CONTEXT, 10)'>NOTIFICATIONS MAP ID 10</a></p>
But If I specify the url path to the server like this, there is no context. I just get the startpage.htm.
<A HREF='javascript:RH_ShowHelp(0,"http://www.ourdomain.com/members/secure/productnamee/help/webhelp/prcdhelp.htm",
HH_HELP_CONTEXT, 23)'>NOTIFICATIONS MAP ID 10</a>
What is also unexplained is this: Using the first link, the framework does not show. I need to click the "show" link.
With the second link, the startpage is displayed and so is the whole framework (TOC, SearchTabs, etc)
I have read some other discussions about whether RoboHelp Server is needed for publishing Web Help or Flash Help to a
web site hosting server. Some say no (and what I did, without RoboHelp server was simply copy files to our server and it is working - though not with context sensitive calls). Others who say "Yes" state it is either a requirement only for Windows Server 2008 or just a tool for collecting statistics and producing reports that you may not need.
I read somewhere else yesterday statements implying that RoboHelp server would support Context Sensitive help. Does that just mean that it would or does it mean it is the only way to support context sensitive help?
If that is true can anyone confirm this? If it is true, do I alone need to publish to RoboHelp server or does every customer of ours require RoboHelp server too if they install our browser-based application and my Flash Help on their own server?
Hi, NeilHaller and welcome to the forums
Short answer: You do NOT need RoboHelp Server to be able to have context sensitive help (CSH). "Plain vanilla" WebHelp and FlashHelp can be deployed with CSH on most any web server and platform (Apache, IIS, Tomcat, UNIX, LINUX, Windows, etc.) From your scenario, my hunch is that you would not need RoboHelp Server, but perhaps this rest of this post will clear up some questions.
Benefit #2 - Security and Permissions - You can have a very "granular" level of control over who can have access to content. For example, you can assign certain end users in the Human Resources department with permissions and they would have to enter a username/password to see confidential content.
Benefit #3 - Empowers Authors
Often, the documentation team is dependent on the IT or Web team before changes can be made. On the other hand, a RoboHelp Server site is "owned" by the RoboHelp documentation team. Once the server is installed and up and running, there is much less reliance on the IT or Web team to do maintenance. The designated RoboHelp author "lead" can add authors, groups, determine who has access to view and/or publish projects and generate feedback reports and many, many other decisions instead of having to pester the IT department to intervene, and hope them respond on a timely basis. (There's more but that's the main benefit.)
Thanks Mr. Daigle for your quick response.
Yes, our customers are not different departments in the same firm but totally remote from us.
Our web application would be supplied to customers all around the world. They would install most of it on their own web or Intranet server along with my help system and then within their company's Intranet, use a browser to access the application. So I would not want to have to put the RoboHelp Server requirement on them for it to work. Our customers will be nowhere near our server where I might have it installed - if I bought it.
Since I posted, I made tiny advancements.
Our server is a UNIX box so my first dumb mistake was not being careful with case when I linked to ROBOHELP_CSH.JS.
So far, as long as the htm file with the link to robohelp_csh.js, the robohelp_csh.js file itself, and the startpage.htm topic are all in the same place - my context sensitive calls are working when the whole system is on my pc.
This scenario works also for Web Help on our UNIX box (after I fixed the spelling mistake).
But no luck with Flash Help. I thought it would work the same way.
One test I must yet try: Is there, was there, a checkbox somewhere in the Flash Help generate dialog that I missed turning on Context Sensitive Help? I will try this next.
It's good to know that you say it should work. That leaves only discovering what I've done wrong in setting it up. Thanks.
