HELP! Convert pdf file from legal size to letter size?
Jan 07, 2010 Jan 07, 2010
Need you HELP!
I have Adobe Acrobat 7.0 Professuonal .
How I can convert pdf file from legal size to letter size?
All information should be same like on legal size, I just need make it smaller to letter size.
Thank you.
57.9K
LEGEND , Jan 08, 2010 Jan 08, 2010
As far as printing to the Adobe PDF printer, DO NOT check the print to file. The printer should take care of that. If you print to file, you are printing to a PS file (NOT PDF) that would then have to be opened in Distiller to create the PDF. I had mentioned this may not be the simplest way, but it does the job for what you needed.
This is not necessarily the most effective way, but I simply printed to a new file with the option to shrink to fit paper (8.5X11). The document shrunk as a result. The PDF is attached.
Thank you very much for you help !!!!!!!!!!!!!!!!!!
But I'm like dummy newbe with Adobe.
Please can you explaine how you get this file. How did you shrink to letter size (8.5X11)?
Will be very appreciated for you response!!!
Since there were no form fields in the file, I simply printed to a new PDF with letter as the paper size and selected
to fit margins.
I try to do same, but can't save to file
I opened my original file (legal size), than File --> Print
Printer name : Adobe PDF
Page Scaling: Reduce to Printer Margins
Print to File (cheked)
Clicked OK. Than in Output File Name field:
L:\test\filename.pdf
Clicked OK. And see error:
"When you create a PostScript file ypu have to send the host fonts.
Please go to the printer propertied, "Adobe PDF Settings" page
and turn OFF the option "Do not send fonts to Distiller" "
What was wrong?
I attached print screens here.
Thanks.
Reprinting/Refrying from Acrobat is no longer associated with best methods practice. If you have a DTP program you can import each page into the DTP program using letter size for each page. Scale the page, then create a new pdf file from there.
I dont know what is DTP , Is it part of Adobe Acrobat?
DTP is a "Desktop Publishing Application" Such as InDesign, Pagemaker...etc.
Jan 09, 2010 Jan 09, 2010
Bill, I got it!
Thank you  very much for your help !!!!!!!!!!!!!!!!!!!!!
