1. Re: Saving with Masks in tact
Curt Y Jan 10, 2010 5:29 PM (in response to rollsnut)When you click "save as" and get that window, make sure there is a check mark in the save options for layers.
2. Re: Saving with Masks in tact
rollsnut Jan 10, 2010 8:00 PM (in response to Curt Y)Curt:
Thanks for your response.
That option remains greyed out when I try your suggestion. The frustration is that I know I have done this before and it was simple.
3. Re: Saving with Masks in tact
Zeno Bokor Jan 11, 2010 1:04 AM (in response to rollsnut)sounds weird enough to warrant a resetting of your preferences: http://forums.adobe.com/thread/375776?tstart=0
4. Re: Saving with Masks in tact
rollsnut Jan 11, 2010 7:50 AM (in response to Zeno Bokor)Zeno:
Thank for the info. In reading the article it seems to imply resetting individual tools. For what I'm dealing with which tool do you think is involved? I looked in EDIT > Preferences and saw nothing about masking tools, where I figured I should look first.
If the problem is with the SAVE portion, since when I SAVE AS my options are greyed out, do you have any thoughts on where I should specifically look?
Thanks again for any help.
5. Re: Saving with Masks in tact
gener7 Jan 11, 2010 8:37 AM (in response to rollsnut)I'm pretty sure it's this part:
"If you have larger trouble, hold down Alt, Ctrl, and Shift keys (Mac: Command, Option, Shift) while starting up Photoshop. A dialog box will appear asking if you wish to delete the preferences file."
A corrupted prefs file can make for many strange problems,and this at least gets that out of the equation by throwing all settings back to default.
6. Re: Saving with Masks in tact
rollsnut Jan 11, 2010 9:13 AM (in response to gener7)Gener7
Thanks for your input. I did what you suggested and noticed changes on my desktop.
I reopened the jpg file, created a partial mask (for testing purposes) and save the file as a psd. Once again, in the SAVE AS dialog box the only “live” checkbox in the Save Options panel was “As A Copy.”
The jpg file I am working on is the only layer. I mention this because I don’t think this is a problem, but I could be wrong. Image is still 8 bit RGB mode.
Since I had batched process the RAW images to jpg I even went back in Bridge, opened the test photo in Camera RAW saved as a jpg (individually, not as a batch) but still the same result.
I’m not giving up but it is a bit frustrating…
Thanks again for everyone’s help.
7. Re: Saving with Masks in tact
Curt Y Jan 11, 2010 9:27 AM (in response to rollsnut)Is you mask recognized as a layer in PS layers box? If not the layers option will be greyed out.
8. Re: Saving with Masks in tact
Zeno Bokor Jan 11, 2010 9:30 AM (in response to rollsnut)could you upload a screenshot of the Save As dialog?
9. Re: Saving with Masks in tact
rollsnut Jan 11, 2010 10:27 AM (in response to Zeno Bokor)I'll try to attach pdf on this response of two screen shots. Comments of each are on right of screen shot.
MaskingScreens.pdf 312.1 K
10. Re: Saving with Masks in tact
Zeno Bokor Jan 11, 2010 10:38 AM (in response to rollsnut)OK, there's nothing wrong with Photoshop. What you have in those two screenshots are active selections, not masks. If you want to save your selection then use Select->Save Selection. When you save files with saved selections the Alpha Channels checkbox from the Save As dialog should be selected
Save and load selections:
http://help.adobe.com/en_US/Photoshop/11.0/WSBB7A7447-383C-40e3-971F-88F5AB2DCB6Aa.html
About layer and vector masks:
http://help.adobe.com/en_US/Photoshop/11.0/WSfd1234e1c4b69f30ea53e41001031ab64-7866a.html
11. Re: Saving with Masks in tact
Curt Y Jan 11, 2010 10:38 AM (in response to rollsnut)Once you have your selection made, just do a ctrl C, crtl V and you have it as a layer. Now when you go to "save as" the layer option will be active.
13. Re: Saving with Masks in tact
rollsnut Jan 11, 2010 1:55 PM (in response to D Fosse-QDEaQ1)Gentlemen.
Thank you all. I don't know how I did what I did before but this has been a valuable education for me and yes, I have all the notes.
I played with it to make sure I understood it and could make it happen. I still have lots to learn about this process but THANK YOU all for your patience and direction. I just hope I am as helpful to others on this forum in the future.
Thank you all again.
Now, to parse out the answer vs. helpful. If you're ok with this....I'll enter it soon
Answer - Zeno
Helpful - Curt v and D Fosse
