1. Re: Nightly build issues?
jdesko Jan 11, 2010 5:22 AM (in response to jdesko)sdk's 13350 and 13363 have the same issue. Last working sdk is 13267.
John
2. Re: Nightly build issues?
CoreyRLucier Jan 11, 2010 5:37 AM (in response to jdesko)I think what may be happening is that the SDK changed the versioning schema of the packaged playerglobal.swc library (in preparation for side by side versioning with 10.1)... Flash Builder is due to synch with this change soon (if not already). If I learn of a workaround for you to be able to leverage nightly SDK builds with older FB I'll follow up.
-C
3. Re: Nightly build issues?
jdesko Jan 11, 2010 8:43 AM (in response to CoreyRLucier)Hello Corey.
As I'm sure you know that would be extremely helpful.
Thanks much for the reply and help,
John
4. Re: Nightly build issues?
Glenn Williams Jan 11, 2010 12:58 PM (in response to jdesko)Hi mate
Its since the team started to get ready for point releases of player. (10.1)
Just remove the two entries for flash player in the sdk list in build properties and add a swc for playerglobals and all will be ok again
You see something like 10.minorplayerversion and playerglobals.swc. remove them both and add playerglobals.swc from the libs/player folder yourself using add swc
hope this helps
glenn
ps if i didnt make this clear just let me know and i'll try again
you could also change the flex config file in the sdk
tinylion development & design
5. Re: Nightly build issues?
Glenn Williams Jan 11, 2010 12:56 PM (in response to jdesko)Sorry just noticed this had already been answered
6. Re: Nightly build issues?
jdesko Jan 11, 2010 2:41 PM (in response to Glenn Williams)Hello Glenn;
Thanks much, that did it! Appreciate very much the reply and help.
Again,
Thanks Glenn and Corey,
John
7. Re: Nightly build issues?
Jason San Jose Jan 19, 2010 4:09 PM (in response to jdesko)Here's a more complete workaround if you want to use the same nightly SDK with multiple projects: http://forums.adobe.com/thread/559312
Jason San Jose
Quality Engineer, Flash Builder
