RH8 HTML
Hi all,
Just wondering (again) if its possible to add a sort feature to a table?
currently, I've got multiple topics that look like the following. They are a breakdown of all fields/buttons and their functions
field name | description | example |
customer id | description of field | example data to be entered |
name | description of field | example data to be entered |
customer order no | description of field | example data to be entered |
job title | description of field | example data to be entered |
this is the order that the fields appear on the user form, I'm wondering if I could add a 'Sort By A-Z' and 'Sort by Appearance' options so the user can view the fields, descriptions, and examples either by the order it appears, or in alphabetical order - all the while the description and example fields moving with the sort.
Just gives a bit more functionality for users so they can find a field quickly if the list is a bit bigger by using an alpha sort
Thanks for any help.
There are several scripts available for this. See http://www.grainge.org/pages/authoring/tables/tables.htm
Check before you choose a script. One of the script goes awry if you have dropdowns in your table.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
thanks, just what I was looking for, hope I can use these with snippets.
time for some testing.
Works perfectly.
BUT.
for some reason, across all browsers, I dont get the Hand icon on the mouse over, instead I get the text selecter icon. On Peters site, the hand displays, however I cant get it to work.
also another query - is it possible to set the list to 'sort' back to its default unsorted listing/view?
any ideas?
Normally, the browser shows a pointer over a hyperlink. You might have the script set up slightly different than Peter.
A quick fix is as following:
Identify the element you want to see a pointer, probably something like TableHeading. In your css, add:
P.TableHeading
Be carefull with this, it may confuse people if they see a mouse cursor they don't expect. Your best bet is still to figure out if you have set the script up exactly as described on Peter's page.
Greet,
Willam
Try this in the .hotspot definition.
cursor: pointer; cursor: hand;}
/* pointer is required for mozilla browsers and must be first. hand is for IE. */
Follow me @petergrainge
Just to be complete,
is a Microsoft standard and only needed if you support IE 5.5 or 5.0
IE version 6 and up support the css standard
Greet,
Willam
So just cursor: pointer; is required?
If you only support IE6 and up, you only need cursor: pointer. The full list with possible styles: http://www.w3schools.com/css/pr_class_cursor.asp
