Related Topics control via "JavaScript:RelatedTopics.Click" broken in RH8
Engaged ,
Apr 08, 2009 Apr 08, 2009
In my RH6 project, I summon a hidden Related Topics control via "JavaScript:RelatedTopics.Click", which works just fine. However, this feature didn't survive the upgrade to RH8. It probably isn't directly related to the upgrade, as I haven't been able to construct this mechanism from scratch in RH8, either. Well, not in a way that works... A plain vanilla unhidden Related Topics control works OK, but not the JS construct.
  • WebHelp
  • RH8 (trial)
  • Project upgraded from RH6
Any hints or suggestions? I'd like to keep using this feature if at all possible.
G.
8.3K
Valorous Hero ,
Hi there
It will still work, but now requires further tweaking!
Before I tell you how to fix it you have to promise to enlist the armies to flood the Adobe RoboHelp developers with Bug Reports on it!
Click here for the Bug Report!!!
Okay, here's the deal. After you insert the control and all that, you need to pop into the HTML code and assign the ID to the code. I'll post some screen captures below. (Click the images to see in full size view)
RoboHelp 7
RoboHelp 8
So all you need to do is to add in the missing ID for the RoboHelp 8 code.
Cheers... Rick
Engaged ,
Rick, you are a giant among men!  I have submitted a bug report.
I am now about halfway there. This is clearly the answer, but I'm stuck on a couple of details. First and foremost, how do I get changes to stick in HTML view? I know I saw something about that somewhere in here, but now I can't find it. I got the id change to stick in one topic, and it now works in Preview mode. However, it choked when I generated output. If I can get the @#$! changes in HTML view to stick, it'll make testing a whole bunch easier!
Thanks! and ever hopeful...
G
Valorous Hero ,
Hi again
Well Carp! FrapDoodle even!
Okay, I may have a workaround here. Give this a go.
I'm attaching a text file for you to use as a guide. It may take half an hour or so for the forums to approve it and make it available once I post. Until then, you will see "QUEUED". You will need to refresh the web page to check the status. Once it's been uploaded, there will be a link.
  1. Download the attached text file and save it to your hard drive.
  2. Open Windows Notepad and open the text file.
  3. Tweak the control in HTML view to add in the missing identifier, then select the workhorse code and copy it to the Windows Clipboard.
  4. Paste the code into the instance of Windows notepad.
  5. Massage the Notepad Template I've supplied per the instructions, then select the modified code and copy to the Windows Clipboard.
  6. Return to editing the topic in Design view. Delete the control from the page.
  7. Click Insert > HTML > Advanced > Script and a dialog should display.
  8. Paste the code into the dialog and click OK.
  9. Compile or Generate and test!
Please let me know if or how well this worked for you.
Cheers... Rick
Engaged ,
Apr 14, 2009 Apr 14, 2009
Well, yes, I've been carping and frapdoodling like crazy. Just wanted you to know that I'd not forgotten you. I had some other fires to put out.
I wasn't able to get the script box approach to work. It gave me errors. Perhaps I wasn't starting and stopping at the right point with what I put in there.
After a bit, I was able to make the changes stick for long enough to do a little testing. Then I dropped sideways down a rabbit hole, trying to figure out how the id of the calling button fits into this. At first, it looked like that was a requirement to make the whole thing work. And then it didn't. Then I noticed that I was applying the "RelatedTopics" id in two separate instances. Well, that can't be right, either. I was having a hard time testing one thing at a time--too many variables!
It's all made my head hurt. I am going to have to table this particular problem for a while and get on with other evaluation and testing of RH8. I *will* return to this problem, though.
Thanks for your help, Rick. I'll be back to this in a week or two. In the meantime, please send me some virtual aspirin.
G.
Engaged ,
Apr 21, 2009 Apr 21, 2009
Update: I've gotten the related topics control to work again, but it's not clean.
Here's the deal. There are two necessary elements that are not appearing in the RH8 topics. The first, as Rick pointed out, was the id="RelatedTopics"  bit. The second missing piece was a chunk of code at the end of the topic, something like:
<?rh-script_start ?><script type="text/javascript" language="JavaScript1.2">//<![CDATA[
if( typeof( InitEffects ) != \'function\' ) InitEffects = new Function();
InitEffects(\'a1\');
//]]></script><?rh-script_end ?>
...where 'a1' is the id of the button I used to access the hidden RelatedTopics control. The button (a1) lives in the template, er, master page (I *must* get used to the new terminology!) header, and the InitEffects code isn't getting carried over to the topic. Unless I include that part (and the missing id), clicking on the control generates an error. (Without the master page involvement, I apparently don't need to worry about the InitEffects part.)
Interestingly, the control needs the id="RelatedTopics" in two places. It does exist in the first spot, but is missing in the second instance. The same appears to be true of the SeeAlso and KeywordSearch controls, BTW. (Before I realized it was supposed to show up twice, in two separate but similar-looking instances, I was going crazy trying to figure out why it was staying and going and staying and going...)
To make matters worse, editing the HTML code is only a transitory solution. As soon as I do anything in the WYSIWYG view for that topic, the HTML changes vanish. (I didn't have any success putting the script in the script box. If I did that, then RH didn't seem to understand that it needed to use that code.) So for the short term, I slapped together a script that adds in the missing bits. So to get output, I close the project, run the script, and then generate via command line. (I can also generate from the project, as long as I don't get into any topics that were altered.) If I need to use this solution for real production, I'll have to do a better script, one that will do a cleaner FAR. For now, while I'm testing, this is OK.
OK, so I have a workaround, and my Related Topics display and operate correctly. Hooray! The next problem is applying this solution to a RoboSource-Controlled project. Now THAT is worrisome.
Rick, thanks for your assistance. I've got more work to do on this problem, but it can wait for a bit, I think.
G
Guest
Aug 20, 2009 Aug 20, 2009
I tried the fix suggested by RoboWizard below and it did not work for me. I'm using RH8 and IE8. It is worth noting that this problem does not occur in Firefox 3.5.2.
It's also worth noting that if you move the Related Topics button to the top of the page, it works fine. I tried putting in at a random spot in the middle of the topic and it did not work.
Bob
Participant ,
Oct 20, 2009 Oct 20, 2009
Rick and Gravenstein,
First of all, I really appreciated being able to find info about this error in the forum. Thank you for that!
Any word on when we can expect a fix from Adobe? (If not, how can I nag them?) I have a help project that contains many hundreds (maybe even thousands) of these links. Every single one of them is generating a script error. A solution that has to be updated using a script each time changes are made in the WYSIWYG view is not viable except as an emergency measure.
(I haven't even tried the fix offered in this thread. The sheer volume of changes necessary precludes manual corrections.)
Eileen
Hi Eileen.
Adobe, like most other software vendors, are not in the habit of announcing when a service/patch release is to be released least of all what will be included in it. All we can do is sit and wait.
Have you considered using a good find and replace tool. FAR is my favourite but BkReplacEm is also widely used and is free.
Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
Participant ,
I'm a frequent user of FAR. But that's not going to help me much if the changes are lost next time I (or one of my colleagues) opens the topic in RH's WYSIWYG editor.
I filled in a bug report and asked for an update on what they plan to do about this. I'll post again here if I hear anything.
(I work for a software company that DOES tell users what releases are in the works and what they will contain. AND we usually keep our word.)
Eileen
Hi Eileen
The best way I'm aware of to "nag" Adobe about an issue is for them to be deluged with Bug Reports. Some folks probably think this is just a place they have made for you to spout off and the reports all drop into the circular file. But trust me, the developers DO see these things. And the more reports about a certain issue they receive, the higher the liklihood of us seeing a fix!
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Engaged ,
Oct 22, 2009 Oct 22, 2009
Can you please share a sample project which exhibits this issue. Can you share a Robohelp 6 project?
I will try to upgrade this to RoboHelp 8, and try to find the root cause of the issue you are facing.
-Praful
Participant ,
Oct 23, 2009 Oct 23, 2009
I'm more than happy to provided this very stripped-down version of one of the projects we have having trouble with.
Note: This is a RH7 project. I'm sorry but I don't have RH6 so I was unable to provide that.
The zip file contains a CHM file. Click on any of the topic in the TOC and you can see how the links work.
Extract the project from the ZIP file and open it in RH8. After it is upgraded, compile the CHM file. In the new file you will see that every link is broken.
We're very interested to hear the results of your examination.
I believe the previous posts in this thread confirm the bug and offer a manual workaround. However, that manual workaround is not a long-term solution because you can't open, edit, and compile the project in RH8 after the "fix".
Regards, Eileen
Hi Praful
Eileen is correct. Please do take a moment and read the thread from the beginning. I've documented the issue with images in this thread as well as having submitted at least two different bug reports reporting the same issue.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Engaged ,
Hi All,
I was able to see the issue regarding the Design time controls, and this I think is a bug which creaped into the RoboHelp 8 Code base.
Surely the RoboHelp team will provide a solution to this issue (can not say when).
But I tried to see if there was a workable solution, which can be achieved by scripting.
So I have a created script file  which will parse the project, and fix all the design time controls and add the missing ID if it was missing.
Now since there is a bug in the HTML editor, so every time a user goes and edit the topic, the ID is sort of automatically eaten up by the HTML editor in RoboHelp 8.
So the only solution is run the script file before generating the ouptut, and this script will fix all the issues related to the Design time control.
I have uploaded a zip file @ https://share.acrobat.com/adc/document.do?docid=b8786cef-681c-4656-9107-f5038466885a
Also I have attached the zip file in the forum post as well.
On unzipping this file, you will find 3 script files, and they do the following things
  1. (Related Topics From Javascript Call.jsx) This file patches the opened project.
  2. (Related Topics From Javascript Call and generate Webhelp.jsx) This File, also patches the opened project, but also generate the webhelp output.
  3. (Related Topics From Javascript Call and generate CHM.jsx)This File, also patches the opened project, but also generate the CHM HTML Help output.
So if you want to generate a webhelp SSL output, just run the 2nd script and it will patch the project and generate webhelp, in one click
and if you want CHM, then run the 3rd script.
Again, do let me know if this really fixes the issue you faced.
And yes, Please report bugs which ever you find to the adobe bug report, and your suggestions as well regarding the features you may want in future RoboHelp release.
Hope this script help
Praful Jain
Participant ,
Praful,
Thank you very much for looking into this. This is more response than we got from our multiple bug reports (for example last April, it looks like, and more recently for me).
If I understand you correctly, using these scripts we should be able to use RH8 as normal, editing the help topics right in the WYSIWYG editor. Then we run the script (as you described) for compiling. Is that correct?
If so, then that's a solution I think my team can live with for now. It's certainly better than maintaining some projects in RH7 and others in RH8 -- and having to keep track of which are which. Of course, a patch or service release would be even better.
Best regards,
Eileen
Engaged ,
Hi Eileen,
You are correct, you can use RoboHelp 8 to edit the HTML topics normally Only before generation you need to run this script file.
Note: Please backup the project before running this script, user should be solely responsible for using this script
Praful Jain
Participant ,
Oct 26, 2009 Oct 26, 2009
Praful, I am looking forward to trying your script solution, but there seems to be a problem with the ZIP file. When I try to open the downloaded file, I get an error message from WinZip: "Cannot open file: it does not appear to be a valid archive. If you downloaded this file, try downloading the file again."
I repeated the download but still cannot open the file.
Could you please create a new ZIP file and make it available.
Thank you
Eileen
Engaged ,
I have uploaded the file @ https://share.acrobat.com/adc/adc.do?docid=b8786cef-681c-4656-9107-f5038466885a
Also I am uploading the zip file again.
Hope this will help.
-Praful Jain
Participant ,
I got the new file and tried it out. I did some spot-checking and haven't found any broken links yet. So your script seems to work perfectly. I will post back here if I find any problems, but in the meantime I'd say that anyone can use these scripts to fix the "JavaScript:RelatedTopics.Click" links in a project that was upgraded from RH7 to RH8.
I can't thank you enough!
/Eileen
Engaged ,
Good to hear that your problem is solved. Please do reply back after verifying the issue completely. This will help others as well.
-Praful Jain
Hi Praful
As the issue isn't strictly related to Related Topics (I believe it's related to general handling of any of the design time controls) will your script work if the control type is Shortcut? Or See Also?
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Engaged ,
Hi Rick,
Script file does not have any thing specific to related links, so my assumption is it should work fine with other design time controls.
Again, I have not verified, some one need to test this script with other design time controls and see if it fixes the issue with controls other then related topic control.
Do let me know if the script does not work for other design time control.
-Praful
Engaged ,
Hi Rick,
I tried creating a sample RoboHelp 7 project and added Related Topic control, See Also Control and Keyword Link Control in different topics, now using javascript call the webhelp output works fine in RoboHelp 7.
I upgraded the project and as discussed earlier, due to some bug in HTML editor, the ID of design time control goes missing.
I ran the script file and generated the webhelp output, and   all the controls started working fine as expected.
So people out there can try this script file for all different types of design time control, and hopefully, the script should fix the ID problem.
-Praful Jain
Hi Praful
Awesome! Thanks so much for testing. I'm hoping to see that a service release appears that corrects that niggling little issue.
What would be cool is if we had an option where we could specify any scripts to run prior to generating output. Perhaps in the SSL dialogs.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
RoboHelp Documentation
Download Adobe RoboHelp
