Submit values and retrieve responses from xml api
Participant ,
Jan 12, 2010 Jan 12, 2010
I use this code to submit to an api
<cfhttp url="<api url>" method="GET" resolveurl="No" ></cfhttp>
I get back
<VerifySignatureResponse>
−<VerifySignatureResult>
<VerificationStatus>Success</VerificationStatus>
</VerifySignatureResult>
</VerifySignatureResponse>
How do I retrieve the response? I ned to get back the Success for the VerificationStatus parameter
Advanced techniques
681
Valorous Hero ,
If the response is xml, try parsing it with XMLParse(). It returns a "structure-like" object. You can then access the elements with dot/array notation. Cfdump the results of XMLParse() to visualize how to access the element you need.
http://livedocs.adobe.com/coldfusion/8/htmldocs/help.html?content=functions_t-z_23.html
http://livedocs.adobe.com/coldfusion/8/htmldocs/functions_t-z_23.html
Jan 13, 2010 Jan 13, 2010
<!--- general case --->
<!--- <cfxml variable="xmlString"><cfoutput>#cfhttp.FileContent#</cfoutput></cfxml> --->
</cfxml>
<cfset statusArray=xmlSearch(xmlString,"//VerificationStatus")>
<cfdump var="#statusArray#">
status: <cfoutput>#statusArray[1].xmlText#</cfoutput>
Participant ,
I don't really understand this cfxml code
In this case you hard coded the word Success.
In the real application the xml is hosted on another server. I send some variables in the URL querystring to the url.
When I enter the url directly in the address bar o the browser I see the xml sheet and the response.
I want to automatically read what was returned through coldfusion
Valorous Hero ,
He was showing you and example of how to parse and view XML data.  Since he did not have access to your web service to get the xml he created an example of it in his code so that he had some xml data to parse and show you.
You can assume everthing in between the <cfxml...> tags is the same as your <cfhttp...> tag.  It creates some xml data to be utilized.
Participant ,
Thanks I used some working code I had on another page and rebuild around this app.
I always need to have these resources next to me because I forget how to build the code
this works for me
<cfset mydoc = XmlParse(CFHTTP.FileContent)>
<cfset pb = mydoc.variable1.XmlChildren>
<cfset size = ArrayLen(pb)>
<cfset myquery = QueryNew("variable1,variable2, variable3")>
<cfset temp = QueryAddRow(myquery, #size#)>
<cfset temp = QuerySetCell(myquery, "variable3", #mydoc.variable3.XmlText#)>
<cfif #mydoc.variable1.variable2.variable3.XmlText# eq "Success">
Action
</cfif>
this works for me
Action
</cfif>
You apparently didn't take the hint, Ian's or mine. What you've done may be correct, it unnecessarily involves too many functions. You could really do it more efficiently, like this
<cfif statusArray[1].xmlText eq "Success">
Action
</cfif>
Documentation
