Numeric Fields
Avatar
Level 1
Newbie needs help. I can't figure this out. My form has simple calculations on it.
EXAMPLE: 1 +1=$2.00
This works fine as long as the user doesn't enter over $10,000.00.
When the user enter over 11,000.00 it changes the pattern to whole numbers without a dollar sign.
This is how I have my pattern set ($z,999.99).
I tried setting the display patterns, I can't get it to work, please help!
You can see my form here. http://www.gcfa.org/PDFs/FundBalanceReport.pdf
Thanks in advance for your help. :~)
Avatar
Level 6
In the form almost all having the pattern of $z,zz9.99 - so u can able to enter max 4 digit number.
if u want more can go with this: ($z,zzz,zzz,zz9.99), if it nver be -Ve number u can remove braces.
Also form did't have enough space to appear the big numbers.
Raghu.
Avatar
Level 1
Yeah, I just now figured it out. The pattern is this $z,zzz,zz9.99 Thanks for your help.
Avatar
Level 1
Thanks again, your help is greatly appreciated. I would give you credit for answering the question but I don't see where I can do it in the forum.
