I am usng RoboHelp 8 to create WebHelp. I recently updated to 8.02. I also generated printed documentation using the HTML headings checkbox, for the first time. One thing I noticed was that I now have two !SSL! folders at different levels of the folder structure where previously, I only had one. Each !SSL! contains a Help folder and a Printed documentation folder.
My RoboHelp Projects\Adobe RoboHelp 8\ABC_PMM_Help_Jan_10\ABC_PMM_Help\!SSL!\Help\!SSL!\Help\
I'm curious as to why this occurred. Is it something I need to be concerned about or take action on?
thanks.
Hi there
I'm doubtful that simply upgrading RoboHelp caused it. More likely it was a snafu caused by copying and pasting or otherwise manipulating the the output folder and start page field of one of your Single Source Layouts. You should carefully examine the layouts you are using to determine which one has been changed and is causing this.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
I looked at my single source layouts and tried several different scenarios but could not duplicate the problem. Looks like it was a copy paste error.
