using a radio button in cfmail / form.
Jan 15, 2010 Jan 15, 2010
Hello;
This is a silly question, but I can't remember how to program in radio buttons for a cfmailer. I have 3 radio buttons, basically, I just need to know what the users choice was when they checked it off. The following is my radio buttons and what I have for code right now. But I'm not grabbing the proper variable, I also tried dumping a few diffrerent variables to see if I could get it.
<input name="type" type="radio" onClick="setVisibility('sub3', 'inline');setVisibility('sub4','none');setVisibility('sub5','none');" value='male' checked="checked"/>Magnets
<input type="radio" name="type" value='female' onClick="setVisibility('sub3', 'none');setVisibility('sub4','inline');setVisibility('sub5', 'none');"/>Paper Steel
<input type="radio" name="type" value='child' onClick="setVisibility('sub3', 'none');setVisibility('sub4','none');setVisibility('sub5', 'inline');"/> both
on my response page, I tried this:
<cfif form.type EQ "male">
if this was their choice, then this set of rules would apply
</cfif>
and so on for the other two choices. This isn't catching my buttons, what am I doing wrong? do I need to make a paramiter for the radio buttons before I can allow it to function? like this?
<cfparam name="FORM.type" default="">
then I can use my if statement? (that isn't working right now either)
here is what I'm trying to dump:
<cfdump var="#form.type#">
<cfabort>
</cfdump>
How do I do this? Can anyone help me?
Advanced techniques
1.2K
Make sure you specify the form's action and method, for example,
<form action="path_to_responsePage.cfm" method="post">
I have all that. I was just posting the code for the radio bu
ttons.
my if statement isn't catching them. can you help me on that? What variables am I supposed to go after?
Replace single quotes by double quotes. Change <input ... value='male' ...>, <input ... value='female' ...>, etc., to <input ... value="male" ...>, <input ... value="female" ...>, ... respectively.
lol, I just tried fixing all that, and
even added an id field. I think it's my "if" statement now.
<cfif form.type EQ ('male')>
you get this
</cfif>
<cfif form.type EQ ('female')>
you get this
</cfif>
<cfif form.type EQ ('child')>
you get this
</cfif>
am I going after this wrong? I know a radio button is treated as a yes/no type input. I also know i can use it like this and still have it work.
Advisor ,
I suspect that you have a problem in some portion of your code that you have not posted. To help debugging I suggest you create a simple test using two pages: input.cfm and action.cfm.  Get the most simple case working then add the javascript, css, and CF code to make your application work.
<!--- contents of input.cfm --->
<html>
<head>
     <title>Input</title>
</head>
<body>
     <form action="action.cfm" method="POST">
          Choose type: <br />
          <input name="type" type="radio" value="male" />     Male<br />
          <input name="type" type="radio" value="female" /> Female<br />
          <input type="submit" />
     </form>
</body>
</html>
<!--- content of action.cfm --->
<html>
<head>
     <title>Action</title>
</head>
<body>
     <cfif form.type eq "male">
          Type is male.
     <cfelseif form.type eq "female">
          Type is female.
     </cfif>
     Here is a cfdump of the form variables:<br />
     <cfdump var="#form#" />
</body>
</html>
Message was edited by: JR "Bob" Dobbs Added sample for action.cfm
you get this
</cfif>
you get this
</cfif>
you get this
</cfif>
It should be without the brackets. What happens when you drop the brackets, like this
<cfif form.type EQ 'male'>
you get this
</cfif>
<cfif form.type EQ 'female'>
you get this
</cfif>
<cfif form.type EQ 'child'>
you get this
</cfif>
What happens when you omit the onClick attribute, and experiment with
<cfinput type="radio" name="type" value="male">
<cfinput type="radio" name="type" value="female">
<cfinput type="radio" name="type" value="child">
I figured it out. It's because I'm using this as my submit button:
<cfinput type="image" name="Submit" validateat="onSubmit" validate="submitonce" style="cursor:Hand;" title="Submit Form" onMouseDown="javascript:this.src='img/submit.gif';" onMouseOver="javascript:this.src='img/submitOver.gif';" onMouseOut="javascript:this.src='img/submit.gif';" value="contact" src="img/submit.gif" alt="Contact Us" width="120" height="20"  border="0">
It doesn't like the image submit button.
So looks like this is out... unless someone knows a better way to get it to work using it. I couldn't even get the form to dump with this in. once I put in a real submit button, it all works.
thanks for the help
Advisor ,
cfsetNewbie,
Does the cfinput of type="image" render an HTML input type="button" tag or a input type="submit" tag in the browser?
Documentation
