Version 8.0.2.208
Conversion of 1200 htm files.
Has anyone experience bullet images in their custom styles changing from RH7 to RH8 and numbers in numbered lists resized?
Bullets
I noticed that all my bullet images have changed. They are OK in Design view, but change when the topics are previewed and generated.
If I attempt to create a new bullet list in the existing topic using the Normal style (Arial 12) and Formatting Toolbar (Bullets), the bullet and text are changed to (Arial 10) and the style name changes to (none) in Design view. Preview and generated is also Arial 10 for both.
Numbered Lists
Most of the existing converted topics used the Normal style and Formatting Toolbar (Numbers) for numbered lists. There is spacing between each numbered line. The numbers and text are in (Arial 12) in Design view, but the numbers are (Arial 10) when the topics are previewed and generated and the text remains (Arial 12).
If I select the numbered list, click the numbered list icon to turn off numbering, and then click to turn on numbering, the numbers and text are (Arial 10) and the style is changed to (none). Output and preview are (Arial 10). The spacing between the numbered items is deleted.
I have to then highlight that list and change the style back to Normal for (Arial 12) text.
If I attempt to create a new numbered list in the existing topic using the Normal style (Arial 12) and Formatting Toolbar (Bullets), the bullet and text are changed to (Arial 10) and the style name changes to (none) in Design view. Preview and generated is also Arial 10 for both.
This has taken up a lot of my time. Any clues?
Donna
The RH conversion gave a lot of problems with lists. The problem is most likely the definition of your lists in your style sheet. To set the correct font-size of the bullets/numbers, add a generic style in your CSS. You want them to be Arial 12pt, so in your CSS (with an external editor), look for OL and UL. In both style definitions, add:
font-family: Arial, sans-serif;
font-size: 12pt;
and remove any other font-size that is specified.
That you see the lists in 10pt, is most likely cause by a parent style that sets the font to 10pt. In your css, look for BODY {} and you may see a font size specified there.
(I thought that you can also set the list font-size trough the Robo CSS editor, but I don't remember how :-s I haven't got RH8 right now, but I can take a look tonight if you like.)
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
Willam,
I'll try your suggestion today.
I had not seen any posts regarding the specific issue that I am having, It's good, in a sense, to know that it is part of conversion issues.
Yes, I would like to know how to set the font list using the Robo CSS editor.
DM
Message was edited by: Captiv8r - Corrected spelling of Willam's name.
I went to the link you provided.I am still confused as to the step by step procedure to fix my custom bullet style that is used throughout my project. Can you globally fix this issue? It would be too time consuming to figure out where in 1200 topics this style is used. I guess I don't understand list styles.
Custom Style = BulletList
My custom (BulletList) style - Design mode:
Preview mode (incorrect)
Another topic using ths sam (BulletList) style - Preview mode (incorrect should be square bullets)
I select Format > Styles in design mode. Right-click on BulletList, select Edit.
If I ceate a bulleted list, the square bullet is selected.
Donna
In RH8, the way you lists work, and the way you apply a list changed. To create a list, use the list button and then select a paragraph. See http://www.wvanweelden.eu/robohelp/lists/list_item_styles.php for setting up a RH8 list and using it.
As for you solution, it depends on how you set up your lists in RH7. If you post an example topic and your style sheet, I'll look for a solution.
Greet,
Willam
Willam,
Thank you for your time. Should I attach my css file and my sample htm topic?
Donna
Yes please.
As far as I can tell from your files, you need to create two list styles: Li.p and Li.p-BulletList. In RH, simply create a list style named "p" and a list style named "p-BulletedList". That should solve most of your problems, if your writers use the paragraph styles in lists consistent.
When the regular paragraph is used in either ordered and unordered lists, you will have to create different stylings. First, create a list style "p", open your CSS in an external editor and look for Li.p. Put OL before Li.p to style ordered lists, such as:
OL Li.p { styles } /*Ordered lists*/
UL Li.p { styles } /*Unordered lists*/
Hope this helps.
Greet,
Willam
William,
Thanks for offering a solution. I will try it one day this week.
Donna
