quote:
Originally posted by: Colum McAndrew
There is no other work around as the window size is hard coded.
What? You think I mess around in that brown smelly stuff I could be way off the mark here but if you look in the RoboHTML directory where you have RH installed there is a DLL called BaseStructureEditorDialogs_Dialog_DHTML_Release_U.dll. I'll stake (not a lot of) money that that will be it.
Bump: I know this comment train is from nine years ago, but I'm wondering if anyone has found a solution to globally (and permanently) resize the tiny drop-down text window? The topic seems to have come up over the years, but no solution that I've found.
I'm running RH 13.0.0.257
Thanks in advance...
Hi Ross
No way I'm aware of to do it. My own preferred method of dealing with it is to avoid it pretty much entirely.
I compose what I want directly below the click text or image in the RoboHelp editor. Once I have things arranged as I want, I select it and cut from the topic. Then I open the little window, select all and paste.
Cheers... Rick
Thanks Rick--that's my workflow, also. I was just hoping beyond hope...
