Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
I have some forms that are being imported into LiveCycle that use the Helvetica font. During the import process I get a message that it had to convert the font to Arial. This is completely throwing off the form layout. Is there a way to have LiveCycle support Helvetica font? Is this an additional purchase (i.e., font library).
The following has evaluated to null or missing:
==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41]
Tip: It's the step after the last dot that caused this error, not those before it.
Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing#if>. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)??
FTL stack trace ("~" means nesting-related):
- Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5]
