Hi all,
I am looking to create a quiz slide in Captivate CS4 using the matching quiz tool. Does anyone know whether or not you can use images as a question rather than text, for example, (see below) i would have the 4 hazard signs on the left and then the 4 answers on the right and the person completing the quiz would have to match the correct answer to the correct picture. If it can be done, where would i start????
Hi there
It can "sort of" be done using Captivate. You wouldn't be able to click the actual image and drag to make the match, but you could certainly insert images just above the text. Then instruct the user to click the text answer and drag to make the match.
If you took this approach you would certainly want to avoid shuffling the answers unless you wanted to totally confuse folks!
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
