Never seen this before, but my TOC is suddenly missing the
+/- expand/collapse topic buttons. Anyone know what the problem is
here? TOC is set to binary.
jd523 • Community Beginner, Jan 25, 2008Jan 25, 2008
I found it. I'm well familiar with the TOC/Project Settings
tabs but didn't originally see the Plus/Minus Squares checkbox.
Actually, it was inactive. I could only activate it when certain
other settings were enabled as well. Anyway, it's fixed. Thanks so
much for your help!
Is this for .CHM or WebHelp? If it's WebHelp, you need some
images. You may obtain some by
clicking
here.
If it's for compiled .CHM, you need to look at the Single
Source Layout properties. Click the Advanced... button, then the
TOC Styles tab. Click to enable Lines from Root, then you will be
able to choose Plus/Minus Squares.
Thanks for your reply. It's compiled Help, .chm. I neglected
to mention that I'm working with an ancient version of RH, SO
ancient, in fact, that I may be beyond the reach of this forum. I'm
running RoboHelp 9.1, as in eHelp's 2001 RH 9.1.
Rick, in my version, the controls that you are speaking of
don't exist. : ) ...other ideas?
much for your help!
