1. Re: Sound Control Question
kglad Jan 23, 2010 7:36 AM (in response to d0brin)you need to use a loop (setInterval or onEnterFrame) to fade volume and then stop your sound (when the volume is 0).
you can have, at most, one sound per movieclip timeline that you can control with actionscript. so, create a unique movieclip for each sound:
var mc1:MovieClip=this.createEmptyMovieClip("mc1",1);
var s1:Sound=new Sound(mc1);
var mc2:MovieClip=this.createEmptyMovieClip("mc2",2);
var s2:Sound=new Sound(mc2);
2. Re: Sound Control Question
d0brin Jan 23, 2010 8:57 AM (in response to kglad)how to do that:
can you help me with some AS code pls
3. Re: Sound Control Question
kglad Jan 23, 2010 12:33 PM (in response to d0brin)if you call fadeAndStop() while passing your sound and its target movieclip, it will fade and stop your sound. the code below need only appear once in your application and can be used to handle any sound.
var fadeSoundI:Number;
function fadeAndStop(s:Sound,mc:MovieClip){
clearInterval(mc.fadeSoundI);
mc.fadeSoundI = setInterval(fadeSoundF,60,s,mc);
function fadeSoundF(s:Sound,mc:MovieClip){
s.setVolume(s.getVolume()-3);
if(s.getVolume()<=0){
s.stop();
4. Re: Sound Control Question
d0brin Jan 24, 2010 1:09 AM (in response to kglad)aha but the thing is that i attach and start the sound on the main timeline and my control btn (the button that controls the sound) is located at this location: p.c whare p and c are movie clips, so how to link this button to control sound initiated on the main scene? Where to put the codes for fading...
5. Re: Sound Control Question
kglad Jan 24, 2010 7:17 AM (in response to d0brin)just like you normally would: use the correct path to the timeline that contains your sound and the correct path to the timeline that contains those functions.
