I have had RH8 for a while, but still worked with my project in RH7. The two versions are installed on two different computers.
I am now about to upgrade my project to RH8, and I have seen all the discussions about people having problems with upgrading to RH8. I have installed the patch 8.0.2. With this patch, will I encounter problems upgrading my project? Are there any precautions I should take (apart from a backup)?
I did try to search the forums, and I know there is a lot of information about the problems that occurred if you upgraded a project before installing patch 8.0.2. But I couldn't find any relevant topics describing how to updgrade a project after installing patch 8.0.2.
Rannveig Østevik
Each project is unique so it is impossible to say you will not hit problems. All I can say is note what is in my Using RH8 article, act on anything relevant, back up as you said and then open the project in RH8.
Follow me @petergrainge
I understand that. But the "folder bug" will not appear when I upgrade the project *after* installing the 8.0.2 patch?
Rannveig Østevik
The purpose of that patch was to stop the folder bug problem and it has worked so far.
Thx for the reassurance I'll give it a try. My project should be quite straight-forward, nothing fancy.
Rannveig Østevik
