I have a reference topic with a large number of bookmarked entries. (This is for good an sufficient reasons.)
Other topics have links to bookmarked locations on this reference topic.
If the reference topic is not already open, these links in the other topics should open the reference topic in a new window, but if the reference topic is already displayed these links should re-use the opened display.
Can anyone help?
Thanks and regards,
Peter
You need to create a JavaScript solution for this, but I wonder whether it will work if you use the script on several pages. See:
http://bytes.com/topic/javascript/answers/469409-check-if-window-open
http://www.webreference.com/js/tutorial1/exist.html
You can also use custom size/auto size popup to call your reference topic. This is probably the quickest and easiest solution.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
It just occured to me that I have a simple script that does just what you want:
function SupportShow()
Support=window.open('ondersteuningssite.htm','Title','status=0,toolbar=0,location=0,menubar=0,resizable=1,scrollbars=1,width=1024,height=600')
Support.focus()
return true;
The hyperlink is: <A href="javascript:void(0);" onClick="SupportShow()" >123</a>
If you want to give the bookmark in a link, modify the script like this:
function SupportShow(sURL)
Support=window.open(sURL,'Title','status=0,toolbar=0,location=0,menubar=0,resizable=1,scrollbars=1,width=1024,height=600')
Support.focus()
return true;
The hyperlink will then be: <a href="javascript:void(0);" onClick="SupportShow('mypage.htm#bookmark')">123</a>
Greet,
Willam
Tthat works, except that browsers don't allow one tab to force focus onto another tab. This apparently is a deliberate design decision to mitigate the effects of malicious code. (The result is that the reference tab starts flashing but doesn't get focus.)
Peter
