Hi
I have installed ColdFusion 9.0, Cold Fusion Builder 3 beta along with IIS7 and i am using Windows 7 Ultimate.
How do i configure coldfusion builder to run my ColdFusion applications?
I am new to ColdFusion. Please help.
This is what i tried doing
>> Open ColdFusion Builder
>> Add a Server
>>Server Name: ColdFusion, Description: Server, Application Server: Jrun, HostName: localhost, Web Port: 8500
Server Home: C:\ColdFusion9
Document Root: \wwwroot
Version: 9.0X
Error message i get when i try to start the server: Starting ColdFusion has encounter a problem.. Ensure that the server is not already running or any application is not using the webserver port.
Thanks in advance.
At the time of installing Cold Fusion 9 i choose build in web server.
Hi bhanu,
I am facing the same problem. Although you faced this problem more than a year ago can you please explain how you fixed this issue ???
Adil Malik
Do you? Is there such a thing?
Adam
I've never heard of ColdFusion Builder 3. Nor have I heard of any such Beta program. If there is currently a ColdFusion Builder Beta program, it is probably a NDA prerelease and should not be discussed in a public forum. just sayin.
