1 Reply Latest reply on Jan 28, 2010 12:54 AM by Rehan ali
    color values
    Rehan ali Level 1
      hi
      when i used eyedroper to to an group object that contain clipping mask of different vector objects to check color ratio by clicking on it but not tell actuall color value that is in clipping mask when i realease clipping mask it gives correct values of an object  help
        • 1. Re: color values
          Scott Falkner Level 6
          The eyedropper will only read the RGB values for the fill in a mask, regardless of the Document Color Mode. This means the CMYK value you used to fill the path is converted to RGB, then back to CMYK in the Color panel. Why would Adobe do this? Better question: why do we all just accept such crap?
