Hello;
I'm having a problem making my code actually output properly. It's not throwing any errors, it actually says there is a record to be read, but my output from my cfloop is wrong I believe. I'm trying to make it break down into 2 columns like this
1 2
3 4
NEXT >
once there is 4 records, the button to go to next page comes up. I know this code is bulky, AI also know my query and next n buttons work fine, so I'm going to post just the query, and the loop with the statements to break it down into 2 columns.
Code:
<cfquery name="newsStory" datasource="#APPLICATION.dataSource#" maxRows=10>
SELECT klNews.title AS ViewField2, klNews.newsDate AS ViewField3, klNews.MYFile, klNews.MYFile2, klNews.ID AS ID
FROM klNews
ORDER BY newsDate
</cfquery>
<cfset halfrecords = newsStory.RecordCount/2>
<cfloop query="newsStory" startRow="#URL.startRow#" endRow="#endRow#">
<cfoutput>
<tr>
<cfif CurrentRow lte halfrecords>
<td width="49%" align="center" valign="top">
#All my content is in here for column 1#
</td>
</cfif>
<cfif Evaluate(CurrentRow+halfrecords) lte newsStory.RecordCount>
<td width="2%" align="center" valign="top"> </td>
#column 2 stuff is here#
</cfif>
</tr>
</cfoutput></cfloop>
it's not showing anything at the moment,
Thank you.
NOTE: small edit to fix a missing TD and url scope in what I just posted.
Might be missing some issue here, but seems like this sort of thing should work just fine.
<!--- default the start row from query to 1 --->
<cfparam default="1" name"url.startrow" />
<cfset newstartrow = url.startrow + 4 />
<!--- make counter to see if we close the tr --->
<cfset closecounter = 0 />
<cfoutput query="yourquery" startrow="#url.startrow#" maxrows="4">
<!--- check to see if odd or even --->
<cfif yourquery.currentrow M
...Copy link to clipboard
<cfoutput query="yourquery">
#data#
<cfif currentrow mod the_number_of_records_per_row is 0>
start a new row.
that doesn't work, I tried it already. I have a next n button on this query. If i run the query on it's own, it works, when I add the startrow and maxrow it crashes.
How would I write this so I could hold 4 records a page with a next n working..
Just using cfloop query and no start row and max row in it doesn't work, just tried. it's somethign in the cfloop I think and the columns, it doesn't like each other. Is there a better way?
<cfif yourquery.currentrow MOD 2 eq 1>
<tr>
<td>#data#</td>
<cfelse>
<td>#data#</td>
</tr>
<cfset closecounter = 1 />
</cfif>
</cfoutput>
<!--- now we see if that last tr was actually closed in case we had odd number of final results --->
<cfif closecounter eq 0>
<td></td>
</tr>
</cfif>
<!--- next link adding 4 to the start row --->
<a href="blah.cfm?startrow=#newstartrow#">NEXT</a>
thank you! That worked.
It just might be the effect of the startRow and endRow. To test that, replace the line
with the line
<cfloop query="newsStory">
