SOLVED
XDPUtilsClientSide class could not be loaded
Avatar
Former Community Member
When I define an xfaForm variable to hold the process data in the workbench I get the following error:
----- Error Message -----
Unexpected error encountered:
The XDPUtilsClientSide class could not be loaded
The schema will be ignored.
If I cklick OK and check the form schema settings in the variable properties the schema is displayed.
If I use the XPath Builder I cannot access the form fields. The path stops at /process_data/[VARIABLE_NAME]/object/data/xdp/datasets/data/FSFIELDS_
I'm using LC 8.0 SP2 version.
Anyone faced this issue?
Chaitanya
1 Accepted Solution
Avatar
Correct answer by
I have not seen this but there is a reference to it here http://forums.adobe.com/message/1366336#1366336.
Steve
Avatar
Correct answer by
Steve
Avatar
Thank you Steve..Your reference solved my problem.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
