Hi xedsternrnx and welcome to our community
I'm assuming you have read this thread you replied to and
still have issues or questions?
I'm a bit confused by your mention of
I'm being told I need to expoert the htm and swf files when I
publish the 1st of 4 linked shows. Does this mean to imply that
only the first of the four shows exists as a .SWF/.HTM file pair
and the other three are possibly .EXE? Or does it instead mean that
you have only published that one and expecting things to work when
you test?
Normally what you do is to create each project that will be
linked, then edit each one to call the next (forging the links, if
you will). Once you do that, you do normally have to ensure all the
output files are inside a single folder. They don't absolutely have
to be, of course. It's just that things are much easier to sort if
they are. Also note that each of the output file sets will contain
a file named
standard.js. Don't let that fool you. It's the same file and
if you copy all output files to a single folder, you will be
prompted that it exists. Don't worry about causing issues by
allowing Windows to overwrite the file. Only one shoud (and will)
exist inside the folder when you are finished.
Cheers... Rick
