Al Baker wrote:
> But when I run the scheduled task, it gets a connection
failure. My guess is
> that the <cfdirectory> and <cffile> tags
(which do work on this instance of CF)
> are unable to access the shared folders on the mapped
drives.
What user does your ColdFusion servers run under. The default
Windows
flavor of ColdFusion runs under a 'localSystem' user and this
user
usually does not have any permissions to write to resources
not on the
local server system. You just need to create or use a domain
user that
has the write/delete permissions to the desired resources and
this
assign this user to be the one ColdFusion runs under.
Again, for the Windows flavor, you change the 'logon' user of
the
ColdFusion service in the Windows Services Panel.
Most likely the mappings you created where associated with
your personal
account and is not available to the ColdFusion server.
Mappings are
usually not neccessary and the prefered method is to just use
an UNC
path of \\serverName\directory\file.ext once the necessary
permissions
are assigned to ColdFusion.
