Locked
RoboHelp 8 Eclipse Help Index/Search Problem
Guest
Jan 25, 2010 Jan 25, 2010
When using RoboHelp 8 to generate Eclipse via the EclipseHelp.jsx script I encounter the following problem: WebHelp generates its own search and index which does not work once placed inside the EclipsePlugin.
Is anyone else using RoboHelp to generate Eclipse Help? How do you overcome this problem?
5.6K
Deleted User
Feb 02, 2010 Feb 02, 2010
Hi Rick,
Please find attached EclipseHelpWithIndex.jsx file which should also generate index.xml and show index in Eclipse index. Please restart eclispe using "eclipse.exe -clean" from command prompt.
Let me know how it goes.
Siddharth
Guest
Jan 27, 2010 Jan 27, 2010
Hello Rick,
True that the WebHelp generated search and index won't work inside the Eclipse. But when you create a new help system, Eclipse takes care of its indexing and makes content searchable.
Refer to: http://www.ibm.com/developerworks/opensource/library/os-echelp/
Excerpt: "Documentation is provided with a collapsible index on the left side and HTML documentation on the right, and can be searched (thanks to the Apache Lucene search engine)."
I created an help system and search is working fine in it. When you search anything for the first time, Eclipse performs re-indexing the help system.
Is search not working on your help?
Siddharth Sodhani
RoboHelp Engineering Team
Guest
Jan 28, 2010 Jan 28, 2010
Search appears to work fine but the Index that shows up isn't for my help but another one that is included with Eclipse the Web Application Dev. User Guide.
Also the "Show" link appears on the help pages. When clicked the non-functional webhelp index and search appears within the help text pane. Attempting to disable this by unselecting In-Topic Nav Bar Element in the SSL properties doesn't work.
Guest
Feb 01, 2010 Feb 01, 2010
I have the show link problem fixed however the Eclipse Index doesn't see my help.
Guest
Hello Rick,
Like Eclipse has a format for TOC, it has the same for Index as well. As of now the script (EclipseHelp.jsx) does not handle it. I am still working on that and should keep you posted.
Siddharth
Guest
Hi Rick,
Siddharth
Guest
Siddharth,
Excellent! That does the trick. Thank you very much.
Best Regards,
RP
Dec 23, 2010 Dec 23, 2010
I had some issues with this specific script.  When I had entries with multiple topics the text was not displaying correctly on the index in Eclipse.  I verified that this was an issue within the eclipse help but it is easily solvable by making each topic a child of a new entry.  I did this by editting the AddTopic function to be like the one below.  I know this is an old thread but it comes up high on the Google search so I thought it should be updated.
function AddTopic(tNode)
     var keyName = tNode.attribute(NAME);
     var url = tNode.attribute(URL);
     var keyXML = XML(String("<entry keyword=\"" + keyName + "\"/>"));
     var topicXML = XML(String("<topic href=\"" + url + "\"/>"));
     keyXML.appendChild(topicXML);
     return keyXML;
Jun 21, 2012 Jun 21, 2012
Hi All,
In the past, I was able to use the EclipseHelpWithIndex.jsx script with the modification:
     return keyXML;
But I have since changed from a Windows XP to a Windows 7 system.  I am running Robohelp 9 as Administrator.  When I run this script now, I see an error: undefined is not an object Line 181, Column 1.
Line 181 is:
ecIndex.write(indexXML.toXMLString());
Any thoughts as to why this is happening?
Dec 17, 2013 Dec 17, 2013
We have the same problem with the EclipseHelpWithIndex.jsx script ("undefined is not an object Line 181, Column 1.") The index.xml file is generated, but only has the single tag "<index/>" in it. The problem surfaced in RoboHelp 8 and still occurs when running the same script under RoboHelp 10.
We assumed the new RoboHelp 10 with its EclipseHelp output option would take care of this problem, but the index portion of the new script code doesn't actually create an index.xml file; it simply returns the value "true" so the script won't fail.
Our company has a critical need to provide EclipseHelp indices and would like to see a solution provided by Adobe.
     - Dan Thornton
Dec 18, 2013 Dec 18, 2013
Dan
These forums are user to user and not monitored by Adobe. To get a solution from Adobe you will need to contact Support or submit a bug report. Please follow this link.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
I understand that you feel Adobe should provide the script but if your developers can fix the script as above, that might be a quicker solution.
@petergrainge
We managed to find a fix to the ModifiedEclipseHelpwithIndex script.  It turns out that in RoboHelp 10 some of the XML files are now Javascript files.
Here is the code we added before the function RunEclipseHelp() section to make a fix:
var baseFolder = projFolder.fsName.concat("\\whxdata");
if(Folder(baseFolder).exists)
      {           ConvertJavaScriptFilesToXML(baseFolder); //Convert JS files in Robohelp 10 to XML files
           var wtoc = File(baseFolder.concat("\\whtoc.xml"));
           var indexFile = File(baseFolder.concat("\\whidx.xml"));
           RunEclipseHelp();
else Window.alert("Generate WebHelp before running this script");
function DoConvertJavaScriptFileToXML(path_to_dir, re, js_file)
      if (!js_file.open('r')) return;
         var content = "";
     while (js_file.tell() != js_file.length)
         content += js_file.readln();
      js_file.close();
       var matches = re.exec(content);
      if (!matches) return;
       var xml_content = re.exec(content)[1].replace(/\\/g, "");
      var xml_file = new File(path_to_dir.concat("\\" + js_file.name.replace("_xml.js", ".xml")));
      if (xml_file.open('w'))
           xml_file.write(xml_content);
           xml_file.close();
function ConvertJavaScriptFilesToXML(path_to_dir)
      var base_folder = new Folder(path_to_dir);
      if (!base_folder.exists) return;
            var re = new RegExp(/^\s*gXMLBuffer\s*=\s*"(.*)";$/m);
      var js_files = base_folder.getFiles("*.js");
      for (var i = 0; i < js_files.length; i++)
           DoConvertJavaScriptFileToXML(path_to_dir, re, js_files);
Adobe Employee ,
Jan 13, 2014 Jan 13, 2014
For RH10, here is a attached script that handles the index.xml generation too in eclipsehelp. Would work for RH10 and higher.
Do let us know if there are any issues.
https://workspaces.acrobat.com/?d=GPhvDwgkj5YWeUK4MBRrFA
Amit
I will give this script a try as well and let you know if there are problems.
THanks,
Lauren
Adobe Employee ,
Feb 27, 2014 Feb 27, 2014
Since workspaces.acrobat.com is retiring soon, placing the (above) refered complete script here itself:
* $$FileName                    EclipseHelp Generator.jsx
* $$Description             This script file generates Eclipse help from RoboHelp Project
*                                        (works for version 9 & above.)
* $$Author                      Praful Jain
* $$Modified By         Amit Agarwal (Added index.xml generation)
* Copyright (c) 2014 Adobe Systems Incorporated. All Rights Reserved.
var mainDlg;
//load all the information
var OPF_TITLE;
var OPF_PROVIDER;
var OPF_VERSION;
var OPF_ID;
var userOutputFolder;
var outputFolder;
var currentProject;
var strTOCOutputXML;
var szCurrentXMLSSLName;
var PAGE = "page";
var BOOK = "book";
var TITLE = "title";
var URL = "url";
var ITEM = "item";
var CHUNK = "chunk";
var NAME = "name";
var REF = "ref";
var INDEXDATA = "indexdata";
var CHUNKINFO = "chunkinfo";
var KEY = "key";
var TOPIC = "topic";
var ECLIPSEHELPCONFXMLFILE = "RH_EclipseHelp.xml";
var PLUGINFILENAME = "plugin.xml";
var OUTPUTTOCFILENAME = "toc.xml";
var OUTPUTINDEXFILENAME = "index.xml";
var listOfTOCFiles = new Array();
//this is the main UI dialog string
var mainDlgResource = "dialog {          \
          properties: { closeButton: false },          \
          text:'Generate Eclipse Help output',          \
          g_Output: Group {          \
                    st: StaticText {          \
                              text:'Help Output Location:'          \
                    et: EditText { \
                              characters: 40          \
                    btn: Button{          \
                              text: 'Browse'          \
          g_SSL: Group { orientation: 'row',  alignment: ['fill', 'bottom'], \
                    st: StaticText {          \
                              text:'Select WebHelp output SSL:'          \
                    ddl: DropDownList { alignment: ['fill', 'center']} \
          tabnav: Panel {          \
                    type:'tabbedpanel',          \
                    helpTip:'Panel: type tabbedpanel',          \
                    minimumSize:[500, 250],          \
                    metaTab: Panel {          \
                                        type:'tab', text:'Eclipse Help Information',          \
                                        orientation: 'column',          \
                                        alignChildren:'right',          \
                                        g_Title: Group {          \
                                                  st: StaticText {          \
                                                            text:'Title:'          \
                                                  et: EditText {          \
                                                            characters: 60          \
                                        g_Provider: Group {          \
                                                  st: StaticText {          \
                                                            text:'Provider Name:'          \
                                                  et: EditText {          \
                                                            characters: 60          \
                                        g_Version: Group {          \
                                                  st: StaticText {          \
                                                            text:'Version:'          \
                                                  et: EditText {          \
                                                            characters: 60          \
                                        g_ID: Group {          \
                                                  st: StaticText {          \
                                                            text:'ID:'          \
                                                  et: EditText {          \
                                                            helpTip:'Enter Plugin ID here',          \
                                                            characters: 60          \
          btnGroup: Group {        \
                    alignment:['right', 'bottom'],          \
                    okBtn: Button {          \
                              text:'Generate'                    \
                    cancelBtn: Button {        \
                              text:'Close'          \
//start
main();
function main() {
    if (isValidType(RoboHelp)) {
        //check for the project open
        currentProject = RoboHelp.getCurrentProject();
        if (isValidType(currentProject)) {
            //we need to show the main dialog now
            showMainDialog();
        else {
            alert("Please open project");
    else {
        alert("Please launch RoboHelp HTML");
function readFile(szFilePath) {
    return RoboHelp.readWholeFile(szFilePath); //this takes care of BOM, encoding and all
function writeToFile(szFilePath, szOutput, bWriteUsingNewFunction) {
    var bSuccess = false;
    if (bWriteUsingNewFunction) {
        bSuccess = RoboHelp.writeWholeFile(szFilePath, szOutput); //this takes care of BOM and encoding as well.
    if (!bSuccess) {
        var fileObj = new File(szFilePath);
        fileObj.open("w");
        fileObj.write(szOutput);
        fileObj.close();
        bSuccess = true;
    return bSuccess;
function AddEventHandlers() {
    mainDlg.btnGroup.okBtn.onClick = OnGenerateBtnClick;
    mainDlg.g_Output.btn.onClick = onBrowseOutputClick;
function showMainDialog() {
    mainDlg = new Window(mainDlgResource);
    //set close button as cancel button now
    mainDlg.cancelElement = mainDlg.btnGroup.cancelBtn;
    //set the generate button command handler
    AddEventHandlers();
    //we need to load the  output SSL dialog now
    LoadDDList();
    //we need to load all the saved values as well
    LoadAllSavedInformation();
    mainDlg.show();
function isEmptyString(szString) {
    var bRetVal = true;
    if (isValidType(szString)) {
        szString = trim(szString);
        bRetVal = szString.length == 0;
    return bRetVal;
function FilePathExists(szFile) {
    var bRetVal = false;
    if (!isEmptyString(szFile)) {
        //check if the file exists or not
        var file = new File(szFile);
        if (isValidType(file)) {
            bRetVal = file.exists;
    return bRetVal;
function trim(szString) {
    return szString.replace(/^\s+|\s+$/g, "");
function ValidateAllInputs() {
    var bRetVal = true;
    var szOutputFile = mainDlg.g_Output.et.text;
    var szHelpTitle = mainDlg.tabnav.metaTab.g_Title.et.text;
    var szHelpProvider = mainDlg.tabnav.metaTab.g_Provider.et.text;
    var szHelpVersion = mainDlg.tabnav.metaTab.g_Version.et.text;
    var szHelpID = mainDlg.tabnav.metaTab.g_ID.et.text;
    //check for output file location
    if (isEmptyString(szOutputFile) || !FilePathExists(szOutputFile)) {
        bRetVal = false;
        Window.alert("Please specify valid Output File Path");
        mainDlg.g_Output.et.active = true;
    else if (isEmptyString(szHelpTitle)) {
        bRetVal = false;
        Window.alert("Please specify Help Title");
        mainDlg.tabnav.metaTab.g_Title.et.active = true;
    else if (isEmptyString(szHelpProvider)) {
        bRetVal = false;
        Window.alert("Please specify Provider Name");
        mainDlg.tabnav.metaTab.g_Provider.et.active = true;
    } else if (isEmptyString(szHelpVersion)) {
        bRetVal = false;
        Window.alert("Please specify Help Version");
        mainDlg.tabnav.metaTab.g_Version.et.active = true;
    } else if (isEmptyString(szHelpID)) {
        bRetVal = false;
        Window.alert("Please specify Help ID");
        mainDlg.tabnav.metaTab.g_ID.et.active = true;
    return bRetVal;
function onBrowseOutputClick() {
    var folder = new Folder(mainDlg.g_Output.et.text);
    var selectedFolder = folder.selectDlg("Select Eclipse Help Output Location");
    if (isValidType(selectedFolder)) {
        mainDlg.g_Output.et.text = selectedFolder.fsName;
    return isValidType(selectedFile);
function ReadXMLChild(xml, tagName, TextField, defaultValue) {
    var child = null;
    if (isValidType(xml)) {
        child = xml.child(tagName);
    if (isValidType(child)) {
        TextField.text = child.toString();
    if (isEmptyString(TextField.text)) {
        TextField.text = defaultValue;
function LoadDDList() {
    var sslManager = currentProject.SSLManager;
    var nCount = sslManager.count;
    for (var i = 1; i <= nCount; i++) {
        var ssl = sslManager.item(i);
        if (ssl.layoutType == RoboHelp.SSLLayoutType.WEBHELP) {
            //this is output, add this to DD
            mainDlg.g_SSL.ddl.add("item", ssl.name);
function SaveAllInformation() {
    //we need to save the 7zip information in common location,
    var xmloutput = new XML("<eclipsehelpinfo/>");
    //we need to save the project specific information in the project folder area only
    //we need the currentProject Path
    var projectXMLFile = currentProject.path + "\\" + ECLIPSEHELPCONFXMLFILE;
    //we need to read all the information now
    var szSSLName = "";
    if (isValidType(mainDlg.g_SSL.ddl.selection)) {
        szSSLName = mainDlg.g_SSL.ddl.selection.toString();
          xmloutput.appendChild(GetNewXMLChild("sslname", szSSLName));
    xmloutput.appendChild(GetNewXMLChild("title", mainDlg.tabnav.metaTab.g_Title.et.text));
    xmloutput.appendChild(GetNewXMLChild("provider", mainDlg.tabnav.metaTab.g_Provider.et.text));
    xmloutput.appendChild(GetNewXMLChild("version", mainDlg.tabnav.metaTab.g_Version.et.text));
    xmloutput.appendChild(GetNewXMLChild("id", mainDlg.tabnav.metaTab.g_ID.et.text));
    xmloutput.appendChild(GetNewXMLChild("outputfile", mainDlg.g_Output.et.text));
    writeToFile(projectXMLFile, xmloutput.toXMLString(), true);
function LoadAllSavedInformation() {
    //we need to load the project specific information as well
    szXML = readFile(projectXMLFile);
    inputXML = null;
    if (!isEmptyString(szXML)) {
        //we need to load the XML and read all the information now
        try {
            inputXML = new XML(szXML);
        } catch (e) { inputXML = null; }
    ReadXMLChild(inputXML, "sslname", mainDlg.tabnav.metaTab.g_Title.et, "");
    var szSSLName = mainDlg.tabnav.metaTab.g_Title.et.text;
    mainDlg.tabnav.metaTab.g_Title.et.text = "";
    ReadXMLChild(inputXML, "title", mainDlg.tabnav.metaTab.g_Title.et, currentProject.name);
    ReadXMLChild(inputXML, "provider", mainDlg.tabnav.metaTab.g_Provider.et, "RoboHelp");
    ReadXMLChild(inputXML, "version", mainDlg.tabnav.metaTab.g_Version.et, "1.00");
    ReadXMLChild(inputXML, "id", mainDlg.tabnav.metaTab.g_ID.et, currentProject.name);
    ReadXMLChild(inputXML, "outputfile", mainDlg.g_Output.et, "");
    //we need to select the ssl name from drop down list now
    UpdateSSLSelection(mainDlg.g_SSL.ddl, szSSLName);
function UpdateSSLSelection(dropdownControl,szSSLName) {
    var currentSelectionIndex = 0;
    for (var index = 0; index < dropdownControl.children.length; index++) {
        if (dropdownControl.children[index].toString() == szSSLName) {
            currentSelectionIndex = index;
            break;
    dropdownControl.selection = dropdownControl.children[currentSelectionIndex];
function GetNewXMLChild(tagName, tagValue) {
    return new XML("<" + tagName + "><![CDATA[" + tagValue + "]]></" + tagName + ">");
function OnGenerateBtnClick() {
    //before going further we need to check if all the things are in place or not
    if (ValidateAllInputs()) {
        //in this case we need to save this information in a file and start the generate process now
        SaveAllInformation();
        OPF_TITLE = mainDlg.tabnav.metaTab.g_Title.et.text;
        OPF_PROVIDER = mainDlg.tabnav.metaTab.g_Provider.et.text;
        OPF_VERSION = mainDlg.tabnav.metaTab.g_Version.et.text;
        OPF_ID = mainDlg.tabnav.metaTab.g_ID.et.text;
            szCurrentXMLSSLName = mainDlg.g_SSL.ddl.selection.toString();
        userOutputFolder = mainDlg.g_Output.et.text;
        mainDlg.close(); //hide the main dialog now
        GenerateEclipseHelpFormat();
function GenerateEclipseHelpFormat() {
    var bSuccess = true;
    ShowMessage("\nStarting the Generation of Eclipse Help Output Now....\n");
    outputFolder = new Folder(userOutputFolder);
    strTOCOutputXML = "";
    //listOfTOCFiles = new Array();
    strProjectName = currentProject.name;
    if (GenerateOutput()) {
        //create TOC File
        bSuccess = bSuccess && CreateTOCFile();
        //create plugin file now
        bSuccess = bSuccess && CreatePluginFile();
        //create Index File
        bSuccess = bSuccess && CreateIndexFile();
        if (bSuccess) {
            ShowMessage("\n EclipseHelp Generated Successfully!");
            alert("EclipseHelp Generated Successfully!");
        else {
            alert("Script Failed");
function CreateTOCFile() {
    ShowMessage("\nCreating TOC File Now");
    var baseTOCFile = new File(outputFolder.fsName + "\\whxdata\\whtoc_xml.js");
    if (baseTOCFile.exists) {
        //read this base TOC now
        PatchEclipseHelpTOC("whtoc.xml");
        bSuccess = true;
    else {
        alert('TOC file not found');
    return bSuccess;
function AddChunk(tNode) {
    var fileName = getAttributeFromXML(tNode,REF);
    var labelName = getAttributeFromXML(tNode,NAME);
    var newFile = new File(outputFolder.fsName.concat("\\eclipse_", fileName));
    listOfTOCFiles.push(newFile);
    var y = new XML("<toc label=\"" + EscapeAllXMLValues(labelName) + "\">");
    y.appendChild(PatchEclipseHelpTOC(fileName));
    var szXMLOutput = GenerateXMLOutput(y.toXMLString());
    writeToFile(newFile.fsName, szXMLOutput);
    var x = new XML("<topic label=\"" + EscapeAllXMLValues(labelName) + "\">");
    return x.appendChild(XML("<link toc=\"" + EscapeAllXMLValues(newFile.displayName) + "\" />")); ;
function GetXMLContentFromJSFile(szBuffer){
          var szRetVal = szBuffer;
          var szTemp;
          var index = szBuffer.indexOf('"');
          if(index!=-1){
                    szTemp = szBuffer.substr(index+1);
                    //find the last index of "
                    index = szTemp.lastIndexOf('"');
                    if(index!=-1)
                              szTemp = szTemp.substr(0,index);
                              //we have the XML convert \" to "
                              szRetVal =ReplaceString(szTemp,"\\\\\"",'\"');
          return szRetVal;
function PatchEclipseHelpTOC(szFileName) {
    var inputTOCFile = new File(outputFolder.fsName + "\\whxdata\\" + szFileName);
          if(!inputTOCFile.exists)
                    szFileName=ReplaceString(szFileName,'.xml','_xml.js');
    var szBuffer = readFile(inputTOCFile.fsName);
          var szXMLBuffer = GetXMLContentFromJSFile(szBuffer);
    var xmlInput = new XML(szXMLBuffer);
    var books = xmlInput.children();
    var ec = XML(String("<toc/>"));
    if (books.length() <= 0) {
        //this case is for whtoc.xml which is always <toc root="whdata0.xml"></toc>
        if (xmlInput.name() == "toc") {
            AddRoot(xmlInput)
    if (books.length() == 1) {
        var tNode = books;
        if (tNode.name() == ITEM) {
            ec = ec.appendChild(AddItem(tNode));
        else if (tNode.name() == BOOK) {
            ec = ec.appendChild(AddBook(tNode));
    else {
        var i = 0;
        for (i = 0; i < books.length(); i++) {
            var tNode = books.child(i);
    return ec.children();
function PatchEclipseHelpIndex(szFileName) {
    var inputIndexFile = new File(outputFolder.fsName + "\\whxdata\\" + szFileName);
          if(!inputIndexFile.exists)
    var szBuffer = readFile(inputIndexFile.fsName);
          var indexXML;
          if(books.length() == 1)
                    var tNode = books;
                    if(tNode.name() == CHUNKINFO)
                              indexXML = AddIndex(tNode);
                    else
              Window.alert("Script failed as index data file is incorrect, please check whidx_xml.js");
    else
        ShowMessage ("Script failed as no index data file was found, please check whidx_xml.js");
        return true;
    if (writeToFile(outputFolder.fsName + "\\"+OUTPUTINDEXFILENAME+"", GenerateXMLOutput(indexXML), true))
        return true;
    else
        ShowMessage ("Script failed in writing index output xml");
        return;
function AddIndex(tNode)
          var fileName = tNode.attribute(URL);
          return ParseIndexFile(fileName.toString());
function ParseIndexFile(szFileName)
                    szFileName = ReplaceString(szFileName,'.xml','_xml.js');
    var keys = xmlInput.children();
          var indexXML = XML(String("<index/>"));
          var i = 0;
          if(keys.length() == 1)
                    indexXML = indexXML.appendChild(AddEntry(keys));
          else
                    for(i=0;i<keys.length();i++)
                              var tNode = keys.child(i);
                              if(tNode.name() == KEY) indexXML = indexXML.appendChild(AddEntry(tNode));
                              else ShowMessage ("Index key did not match in the XML");
          return indexXML;
function AddEntry(tNode)
          var keyChildren = tNode.children();
          var i = 0;
          if(keyChildren.length() == 1)
                    var tChild = keyChildren;
                    if(tChild.name() == KEY) keyXML = keyXML.appendChild(AddEntry(tChild));
                    else if(tChild.name() == TOPIC) keyXML = keyXML.appendChild(AddTopic(tChild));
          else
                    for(i = 0; i < keyChildren.length();i++)
                              var tChild = keyChildren.child(i);
          return keyXML;
          return topicXML;
function AddItem(tItem) {
    var szName = getAttributeFromXML(tItem, NAME);
    var szURL = getAttributeFromXML(tItem, URL);
    var txt = "<topic label=\"" + EscapeAllXMLValues(szName) + "\" ";
    if(!isEmptyString(szURL))
        txt += "href=\"" + EscapeAllXMLValues(szURL) + "\" ";
    txt += "/>";
    return new XML(txt);
function AddBook(tBook) {
    var x = AddItem(tBook);
    var tChildren = tBook.children();
    var i = 0;
    if (tChildren.length() == 1) {
        var tNode = tChildren;
        if (tNode.name() == ITEM) x = x.appendChild(AddItem(tNode));
        else if (tNode.name() == BOOK) x = x.appendChild(AddBook(tNode));
        else if (tNode.name() == CHUNK) x = AddChunk(tNode);
    else {
        for (i = 0; i < tChildren.length(); i++) {
            var tNode = tChildren.child(i);
    return x;
function AddRoot(xl) {
    var tXML = XML(String("<toc label=\"" + EscapeAllXMLValues(OPF_TITLE) + "\"/>"));
    var res = PatchEclipseHelpTOC(getAttributeFromXML(xl, "root"));
    var tX = tXML.appendChild(res);
    var ecTOC = File(outputFolder.fsName.concat("\\"+OUTPUTTOCFILENAME));
    var szXMLOutput = GenerateXMLOutput(tX.toXMLString());
    writeToFile(ecTOC.fsName, szXMLOutput, true)
function CreatePluginFile() {
    ShowMessage("\nCreating Plugin File Now");
    var pluginfile = new File(outputFolder.fsName + "\\" + PLUGINFILENAME);
    var szXMLOutput = "<plugin ";
    szXMLOutput += "name=\"" + EscapeAllXMLValues(OPF_TITLE) + "\" ";
    szXMLOutput += "id=\"" + EscapeAllXMLValues(OPF_ID) + "\" ";
    szXMLOutput += "version=\"" + EscapeAllXMLValues(OPF_VERSION) + "\" ";
    szXMLOutput += "provider-name=\"" + EscapeAllXMLValues(OPF_PROVIDER) + "\" ";
    szXMLOutput += ">\n";
    szXMLOutput += "<extension point=\"org.eclipse.help.toc\">\n<toc file=\""+OUTPUTTOCFILENAME+"\" primary=\"true\" />\n";
    if (isValidType(listOfTOCFiles) && listOfTOCFiles.length > 0) {
        for (; listOfTOCFiles.length > 0; ) {
            var tFile = listOfTOCFiles.pop();
            szXMLOutput += "\n<toc file=\"" + EscapeAllXMLValues(tFile.displayName) + "\"  />";
    szXMLOutput += "</extension>";
    szXMLOutput += "<extension point=\"org.eclipse.help.index\">";
    szXMLOutput += "<index file=\""+OUTPUTINDEXFILENAME+"\"/>";
    szXMLOutput += "\n</extension>\n</plugin>";
    return writeToFile(pluginfile.fsName, GenerateXMLOutput(szXMLOutput), true);
function CreateIndexFile() {
        ShowMessage("\nCreating Index File Now");
        var baseIndexFile = new File(outputFolder.fsName + "\\whxdata\\whidx_xml.js");
        if (baseIndexFile.exists) {
            // read this base Index now
            bSuccess = PatchEclipseHelpIndex("whidx.xml");           // the bSuccess is false if the index is not patched
        else {
            alert('Index file not found');
        return bSuccess;
function GenerateXMLOutput(szOutput) {
    var szRetVal = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";    //start of XML file
    var xml = new XML(szOutput);
    return szRetVal + xml.toXMLString();
function GenerateOutput() {
    ShowMessage("\nGenerating Webhelp output...");
    var bWebHelpOutputExists = false;
        if (ssl.layoutType == RoboHelp.SSLLayoutType.WEBHELP && ssl.name == szCurrentXMLSSLName) {
            bWebHelpOutputExists = true;
            break;
    if (!bWebHelpOutputExists) {
        alert("WebHelp Output SSL does not exist. Please create one");
    else {
        //we need to check if there is a multiple context defined or not
        if (!isMultipleContentCategoryDefined(ssl)) {
            var szOldSSLOutputFileName = ssl.outputFileName;
            //we need to clean up the folder as well now
            CleanUp(outputFolder, true);
            if (!outputFolder.exists) {
                CreateFolderRecursive(outputFolder);
            var szOldBreadCrumbOption;
            var szOldTOCShowOption;
            //we need to set some values like
            //reset breadcrumb and reset toc navigation
                var sslFilePath = currentProject.path + "\\" + ssl.name + ".ssl";
                if (!FilePathExists(sslFilePath) || isEmptyString(szOldSSLOutputFileName)) {
                    ssl.generate();
                //get the old values first
                szOldBreadCrumbOption = ssl.getSpecificProperty("m_bAddBreadcrumbs");
                szOldTOCShowOption = ssl.getSpecificProperty("m_strTopicBarSelOrder");
                //now set the new values
                var szNewTOCShowOption = szOldTOCShowOption;
                szNewTOCShowOption = ReplaceString(szNewTOCShowOption, "TpcShow|", "");
                ssl.setSpecificProperty("m_bAddBreadcrumbs", "0");
                ssl.setSpecificProperty("m_strTopicBarSelOrder", szNewTOCShowOption);
            //before generate first save the old HTML output option
            var bHTMLOutputOption = false;
                bHTMLOutputOption = RoboHelp.convertToHTMLOutput;
                RoboHelp.convertToHTMLOutput = true;
            ssl.outputFileName = outputFolder.fsName + "\\index.htm";
            ssl.generate();
            ShowMessage("\nWebHelp Output Generated successfully");
            var tempFile = new File(szOldSSLOutputFileName);
            tempFile = tempFile.parent;
            if (!tempFile.exists) {
                CreateFolderRecursive(tempFile);
            ssl.outputFileName = szOldSSLOutputFileName;
                RoboHelp.convertToHTMLOutput = bHTMLOutputOption;
                ssl.setSpecificProperty("m_bAddBreadcrumbs", szOldBreadCrumbOption);
                ssl.setSpecificProperty("m_strTopicBarSelOrder", szOldTOCShowOption);
        else {
            alert("Multiple content categories are not supported for Eclipse Help generation.");
    return bWebHelpOutputExists;
function isMultipleContentCategoryDefined(ssl) {
    var iCount = 0;
    if (isValidType(ssl)) {
        var contentManager = ssl.ContentManager;
        if (isValidType(contentManager)) {
            iCount = contentManager.count;
    return iCount > 1;
function ReplaceString(szStringToBeReplaced, szStringToSearch, szStringToReplace) {
    try {
        if (isValidType(szStringToBeReplaced) && isValidType(szStringToSearch) && isValidType(szStringToReplace)) {
            var myPattern = new RegExp(szStringToSearch, "gi");
            return szStringToBeReplaced.replace(myPattern, szStringToReplace);
    } catch (e) {
        ShowMessage("\nError While calling Replace String function check the string");
    return szStringToBeReplaced;
function EscapeAllXMLValues(szTemp) {
    if (!isEmptyString(szTemp)) {
        // special handling for XML restricted characters - Begins //
        szTemp = ReplaceString(szTemp, "&", "&");
        szTemp = ReplaceString(szTemp, "<", "&lt;");
        szTemp = ReplaceString(szTemp, ">", "&gt;");
        szTemp = ReplaceString(szTemp, "'", "&apos;");
        szTemp = ReplaceString(szTemp, "‘", "&apos;");
        szTemp = ReplaceString(szTemp, "’", "&apos;");
        szTemp = ReplaceString(szTemp, "\"", "&quot;");
        szTemp = ReplaceString(szTemp, "“", "&quot;");
        szTemp = ReplaceString(szTemp, "”", "&quot;");
    // special handling for XML restricted characters - ends //
    return szTemp;
function CopyFilesFolder(srcFolder, tarFolder) {
    var listOfFiles = new Array();
    listOfFiles = srcFolder.getFiles("*.*");
    for (; listOfFiles.length > 0; ) {
        tFile = listOfFiles.pop();
        if (tFile instanceof Folder) {
            var tempFolder = Folder(tarFolder.fsName.concat("\\", tFile.displayName));
            if (tempFolder.exists == false) {
                CreateFolderRecursive(tempFolder);
            CopyFilesFolder(tFile, tempFolder);
        else {
            tFile.copy(tarFolder.fsName.concat("\\", tFile.displayName));
function CreateFolderRecursive(folderObject) {
    if (isValidType(folderObject) && !folderObject.exists) {
        //try to create the parent first of all
        CreateFolderRecursive(folderObject.parent);
        folderObject.create();
function CleanUp(folder, deleteRootFolder) {
    if (folder.exists == false) {
        return false;
    var listOfFiles = folder.getFiles("*.*");
    var tFile;
            CleanUp(tFile, true);
        else {
            tFile.remove();
    if (deleteRootFolder == true) {
        folder.remove();
    if (isValidType(listOfFiles)) {
        delete listOfFiles;
function getAttributeFromXML(xml, attributeName) {
    var szRetVal = null;
        var attributeValue = xml.attribute(attributeName);
        if (isValidType(attributeValue)) {
            szRetVal = attributeValue.toString();
    return szRetVal;
function isValidType(value) {
    if (typeof (value) !== 'undefined' && value != null) {
        return true;
    return false;
function ShowMessage(msg) {
    RoboHelp.project.outputMessage(msg);
Aug 01, 2022 Aug 01, 2022
Hi, I'm evaluating RoboHelp 2020.
Thanks for providing the Eclipse Help Generator script. However,  I'm seeing Unterminated string literals, invalid characters and so on. Is there an updated version of the script available?
Eclipse Help is a required delivery mechanism for us.
Alex
Guest
Could you share your WebHelp SSL properties with me?
RP
RoboHelp Documentation
Download Adobe RoboHelp
