Hi all,
I have java.lang.StackOverflowError when task is assigned to user.in the workflow:
User A escalate task to User B.
In between there are several JDBC call and set value operation.
When the step Assign to User B is created (User Task), I have java.lang.StackOverflowError. Below is the exception from adminui > stalled operation:
nested exception is: java.lang.StackOverflowError: com.ibm.ws.exception.WsEJBException: nested exception is: java.lang.StackOverflowError
at com.ibm.ejs.container.LocalExceptionMappingStrategy.mapException(LocalExceptionMappingStrategy.java:203)
at com.ibm.ejs.container.LocalExceptionMappingStrategy.mapCSITransactionRolledBackException(LocalExceptionMappingStrategy.java:410)
at com.ibm.ejs.container.EJSContainer.postInvoke(EJSContainer.java:4092)
This exception just occurred once and cannot retry.
Previously I have ran many times and it never happened before.
Is there any possible reason that makes java.lang.StackOverflowError happen in this case?
Thank you and regards,
Anh
Total Likes
There was a bug in the event processing that caused a stack overflow but it was fixed a long time ago. I get an error opening your attached zip so i can't look at that. What version and service pack level of ES are you running?
ES = LC 8.0.1.sp#,
ES Update1 = LC 8.2.1.sp#
ES 2 = LC 9.0.0 (no sp available yet)
Jon
Total Likes
Hi Jon,
Thank you for your reply.
My client uses Livecycle ES 8.2.1 SP2
I paste the exception here in case the zip file has problem (but i still can open and view it ...):
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_caf58c4f.doSupports(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:104)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:109)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:110)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:91)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:215)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:57)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:724)
at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:466)
at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:863)
at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBean.java:2773)
at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncContinueBranchCommand(ProcessEngineBMTBean.java:2528)
at com.adobe.workflow.engine.EJSLocalStatelessadobe_ProcessEngineBMTEJB_7d3cbd67.asyncContinueBranchCommand(Unknown Source)
at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControllerBean.java:144)
at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandControllerBean.java:99)
at com.ibm.ejs.container.MessageEndpointHandler.invokeMdbMethod(MessageEndpointHandler.java:1014)
at com.ibm.ejs.container.MessageEndpointHandler.invoke(MessageEndpointHandler.java:747)
at $Proxy0.onMessage(Unknown Source)
at com.ibm.ws.sib.api.jmsra.impl.JmsJcaEndpointInvokerImpl.invokeEndpoint(JmsJcaEndpointInvokerImpl.java:201)
at com.ibm.ws.sib.ra.inbound.impl.SibRaDispatcher.dispatch(SibRaDispatcher.java:788)
at com.ibm.ws.sib.ra.inbound.impl.SibRaSingleProcessListener$SibRaWork.run(SibRaSingleProcessListener.java:585)
at com.ibm.ejs.j2c.work.WorkProxy.run(WorkProxy.java:419)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
Caused by: java.lang.StackOverflowError
at java.util.ArrayList.readObject(ArrayList.java:617)
at sun.reflect.GeneratedMethodAccessor30.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1036)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1848)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1755)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1341)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1947)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1871)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:378)
at java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:509)
at com.adobe.workflow.pat.service.PATExecutionContextImpl.readObject(PATExecutionContextImpl.java:1377)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:79)
at java.util.HashMap.readObject(HashMap.java:1318)
at sun.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at com.adobe.idp.jobmanager.ejb.JobManagerBean.deserializeObject(JobManagerBean.java:1481)
at com.adobe.idp.jobmanager.ejb.JobManagerBean.createJob(JobManagerBean.java:188)
at com.adobe.idp.jobmanager.ejb.EJSLocalStatelessJobManagerBeanLocalEJB_f3d02f9b.createJob(Unknown Source)
at com.adobe.idp.jobmanager.service.JobManagerService.createJob(JobManagerService.java:77)
at sun.reflect.GeneratedMethodAccessor389.invoke(Unknown Source)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:342)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(EjbTransactionCMTAdapterBean.java:212)
... 34 more
Total Likes
I was able to open the zip and confirmed that this bug has been fixed on 8.2.1.2. I think you have to contact support to get it. fix id = QF 2.62.
Jon
Hi Jon,
Thank you for your reply. I will contact Adobe support for this issue.
Anh
Total Likes
