RH7 - Where do I find the URL?
Guest
Feb 02, 2010 Feb 02, 2010
I am publishing a new project using WebHelpPro. Everything published fine and it looks great. Now I need to find the URL so I can create my hyperlink to the project. Where can I find the URL?
Your help is greatly appreciated.
~Jennifer
664
LEGEND , Feb 03, 2010 Feb 03, 2010
Check out this post which has the link for RH Server 8:
http://notcolin.wordpress.com/2009/08/04/robohelp-server-8-areas-the-path-to-enligtenment/
  • Read the RoboColum(n) for a tips, tricks and musings on the Technical Communication Suite products.
  • Follow the RoboColum(n) on Twitter
You would only use WebHelpPro if you're using RoboHelp Server. The lead .htm page is usually your_project_name.htm inside the project_name\!SSL!\ folder where you created the help.
Guest
We do have a RoboHelp Server. Maybe I'm using the wrong name. I'm directing the link to the prject name.htm, not the lead page.htm. I'll try that. Thank you!
Just making sure - lots of people think that the "Pro" version must be better ;>)
Guest
I've been trying everything and this is still not creating a URL that works. Does this look remotely corre
ct?
http://roboengine/Robo/Projects/UF-Memo-Manual_WebHelp_Pro/UF-Memo-Manual.htm
First, are you generating the WebHelpPro files to a local directory or to some web server? The launch point in either case would be:
\wherever you're going to be putting the WebHelpPro files\project_name.htm
So to test it locally, it would be in a path like: c:\projects\project_name\!SSL!\WebHelpPro\project_name.htm
If you told it in your SSL properties to publish it to your webserver, it would look something like this:
http://www.server_name.org/help/WebHelpPro/project_name.htm
We've seen this confusion before. A RoboHelp Server could mean any server dedicated to hosting the WebHelp output. RoboHelp Server is a piece of software that gets installed on a server, not the same thing.
Just wanted to clarify that in case there is a misunderstanding.
Follow me @petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
