I was wondering if anyone had the time to take a look at the source code on my copyright page. I have been using this page for years, and adjusting it when the need arises. I recently made some changes and, when I generate the project in RH6, I get an error message saying a Runtime Error has occurred.
I've played with the code all day today, to no avail. Perhaps I should call support? I'm not sure how to proceed. . .
Sharon
Are you sure the two are linked?
Have you checked with another project?
If you have, then exclude this page with a conditional tag and see if it still errors.
Finally import that page into a brand new project and see if that errors.
Post back the results and we'll take it from there.
Follow me @petergrainge
The error just appears when that page loads; no other page is impacted.
In your project only or if you import that topic into a new project?
Hi there
Was there a zip I missed or something? You are asking us to look at what? I'm not seeing anything to look at.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
I think Sharon was being courteous and asking if someone would look if she posted it, rather than posting and assuming someone would look.
She has since contacted me to say she will do some more testing along the lines I suggested.
Apart from the file being an output file, on line 129, you have a second doctype declaration: <!doctype HTML public "-//W3C//DTD HTML 4.0 Frameset//EN">. Try removing that.
Browsers will normally forgive you, but I can imagine that RH has a problem with it.
Greet,
Willam
If the problem file is from the source, the fact that the source has an output file in it would likely cause this problem. Was the page imported from the output of another project instead of from the source?
I'm going to answer this to the best of my abilities.
First of all, I did import the source file, not the output file, into another project, though I repeated that exercise again to be sure that is what I had in fact done. With that clarified, I proceeded to take out the text as recommended by Willam. I did begin to realize that all my source files have this code.
After generating, I viewed the output files in both Firefox and IE6. In Firefox, I had no problems; In IE, the error remained. I decided to debug in IE, and (not being a programmer), I can only surmise that my results were that something was wrong with IE! I upgraded to IE8, and all went swimmingly from then on.
If someone can explain this more clearly, that would be terrific. . .in the meantime, thank you all for your help, as always.
Have a wonderful weekend.
Sharon
For the record, I also tested the page and various links in IE 6 on someone else's system, and all seemed fine.
Willam, can you elaborate on why that code is troublesome? As I mentioned, I have it throughout the system. Should I delete it throughout, in your opinion?
I wonder, for completeness, whether there are other ways to ensure this will work correctly in production.
Sharon
The doctype declaration is obligatory. It tells the browser what kind of webpage it is rendering (HTML4.01 / XHTML 1.01 etc). This also tells the browser how to render that page. If you use the strict doctype for HTML, even IE will try to render the page standards compliant.
The doctype declaration has to be the first code in any topic when you use HTML (RoboHelp 7 and before), or directly follow the XML declaration (RoboHelp 8). If there is more than one doctype declaration, your topic is malformed HTML. This should normally be no big deal, since many browsers are quite forgiving. See also: http://www.w3schools.com/tags/tag_DOCTYPE.asp
As the problem was in IE, I wouldn't worry about it. If you do come across a second (or later) doctype declaration, it's best to delete it. It's not a very big deal, but if you are having trouble with a topic, it might be the cause of all your troubles.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
Thank you, William.
