Show 4 replies
1. Re: Problem uninstalling InDesign CS4
Joel Cherney Feb 4, 2010 6:34 PM (in response to rlafoto1)Not for the uninstaller, no, but there's a Clean Script you might want to look into.
Edit: I suppose I should suggest the generic "turn UAC off before you uninstall," but I don't know what you've already tried.
2. Re: Problem uninstalling InDesign CS4
P Spier Feb 5, 2010 3:19 AM (in response to rlafoto1)If you are having trouble with the uninstaller it may indicate a local system problem, so the script may not run either, but it's certainly worth a try: Run the CS4 Clean Script
3. Re: Problem uninstalling InDesign CS4
rlafoto1 Feb 5, 2010 10:08 AM (in response to P Spier)Thanks All,
I was told by Adobe Tech to uninstall all CS4 programs to solve a problem with Premiere Pro. I could not uninstall InDesign. I ran CS4 clean script and reinstalled Premiere Pro. Now both InDesign and Premiere Pro work.
Take care,
Randy
4. Re: Problem uninstalling InDesign CS4
rlafoto1 Feb 5, 2010 10:09 AM (in response to Joel Cherney)Thanks - it worked...
Randy
