check boxes toggle using form.submit()
Participant ,
Feb 05, 2010 Feb 05, 2010
Hi guyz, when a checkkbox is clicked other than "form.locAll", it should store the value of those form.location in a session so that I can use them during the session. By default form.locAll is checked... The problem is: if any other cb is checked, when I clicked the "All" cb it doesnt reset other form.location cboxes. Basically it should toggle between form.locAll and form.location.
Thank you alll.
----------Code----
<cfparam name="form.location" default="">
<cfparam name="session.location" default="All">
<cfparam name="url.reset" default="0">
<cfparam name="url.location" default="All">
<cfif isdefined('form.LocAll') and trim(form.LocAll) eq "All" and not isdefined('form.location')>
<cfset form.location = "">
<cfelseif isdefined('form.location') and form.location neq "">
   <cfset session.location = form.location>
</cfif>
<form>
          <cfoutput query="GetDivisions">
          <input type="checkbox" name="<cfif trim(division) eq "All">LocAll<cfelse>location</cfif>"  id="#trim(DIVISION)#" value="#trim(DIVISION)#"          onClick="document.LOAAcc.submit();"
          <cfif form.location eq "" and trim(division) eq "All">
           checked="checked"
          <cfelse>
           <cfloop list="#form.location#" index="a">
            <cfif trim(a) eq trim(DIVISION)>checked="checked"</cfif>
           </cfloop>
          </cfif>
          <label for="#DIVISION#">#DIVISION#</label>
          </cfoutput>
</form>
Advanced techniques
805
What you are trying to accomplish is not clear.  No matter what it is, the following things might be preventing it.
This
combined with this
is a problem because form.location will always be defined.
This:
           checked="checked"
          <cfelse>
           </cfloop>
          </cfif>
has a lot of potential to go bad.
First, if GetDivisions has more than one record, the user can only select one checkbox because of the onClick event.  Of course it's not clear what would be submitted because your form does not have a name.
Next, looping through a list to set a checked attribute is logically the same as using ListFind.  If nothing else, it looks strange.
Participant ,
it is resolved. it was a small logic operation. thank you Dan.
Good. Please kindly show the solution or, at the very least, explain briefly how you resolved the problem. Then, mark this thread as solved.
It will help those who come here looking for answers to similar problems. You know it makes sense. Thank you.
Participant ,
Feb 08, 2010 Feb 08, 2010
The changes are:
<cfif isdefined('form.location') and form.location neq "">
<cfparam name="form.LocAll" default="">
</cfif>
<cfif isdefined('session.location') and session.location neq "All" and isdefined('url.indicator')>
</cfif>
<cfif isdefined('url.reset') and url.reset eq 1 and form.location eq "">
<cfset session.location ="All">
</cfif>
           <cfif trim(division) neq "All">
           <cfelse>
           onClick="javascript:window.location='index.cfm?Reset=1';"
           </cfif>
           <cfif session.location eq "All" and trim(division) eq "All">
            checked="checked"
           </cfif>
          <cfelse>
           <cfif form.location neq "">
            <cfloop
             index="a">
             </cfloop>
            <cfelseif session.location neq "">
             <cfloop
             list="#session.location#"
              index="a">
              </cfloop>
            </cfif>
          </cfif>
          </cfoutput>
Documentation
