1. Re: Deinterlacing Question
Jeff Bellune Feb 4, 2010 10:32 AM (in response to Blue_Devil1)There's a lot of subtle stuff going on here.
Progressive H.264 export in CS3 goes back to your source footage and then looks at what the sequence is doing to it, if anything. Since you haven't told Pr to deinterlace the footage, the AME constructs a full progressive frame out of the interlaced fields of the source. That results in combing.
When you tell Pr to deinterlace the footage before encoding it, either in-sequence or by using the Always Deinterlace check box, then Pr passes a deinterlaced progressive frame to the AME to be encoded as progressive H.264. No combing.
Bottom line: to get true progressive footage out of CS3, you have to explicitly tell Pr to deinterlace the footage.
-Jeff
2. Re: Deinterlacing Question
Blue_Devil1 Feb 4, 2010 11:46 AM (in response to Jeff Bellune)Jeff,
Thanks a lot. Great explanation. (I gave you an "answered" ).
Apparently I've been encoding as "progressive " for years and not doing anything except compressing the size of the file.
John
3. Re: Deinterlacing Question
Ann Bens Feb 4, 2010 4:15 PM (in response to Jeff Bellune)This is interesting.
Does this apply to H264 only or to other formats like wmv which is by default progressive.
4. Re: Deinterlacing Question
Jeff Bellune Feb 4, 2010 4:19 PM (in response to Ann Bens)The behavior is independent of the codec or format. Force deinterlacing and export progressive and you'll get the results you expect. Export interlaced material as progressive without explicitly deinterlacing the source video, and you'll get unexpected results.
-Jeff
5. Re: Deinterlacing Question
Ann Bens Feb 4, 2010 4:22 PM (in response to Jeff Bellune)This is quite surprising because i have
rendered to wmv progressive for the web many times and never
seen combing.
6. Re: Deinterlacing Question
Jeff Bellune Feb 4, 2010 4:22 PM (in response to Jeff Bellune)NB: This situation is "remedied" in CS4. There is no "Always Deinterlace" check box in the export settings, and if you export interlaced material as progressive, CS4 is smart enough to do the deinterlacing for you automatically. Select "Maximum Render Quality", and the deinterlacing will be much better than the deinterlacing in CS3.
Again, the behavior in CS4 is independent of the format and codec chosen for export.
-Jeff
7. Re: Deinterlacing Question
seen combing.
That's why I called the results, "unexpected".
-Jeff
EDIT: IIRC, even with H.264, not all of John's video exhibited combing. The flames were just one (the only?) part that did.
8. Re: Deinterlacing Question
Ann Bens Feb 4, 2010 4:38 PM (in response to Jeff Bellune)In that case i hope the results stay 'expected' because
setting Always Deinterlace to several Hundreds of clips is no fun.
9. Re: Deinterlacing Question
Ann Bens Feb 4, 2010 4:40 PM (in response to Jeff Bellune)Yes that is what i was thinking of John video.
10. Re: Deinterlacing Question
Ann Bens Feb 4, 2010 4:50 PM (in response to Ann Bens)The manual does not tell you all this stuff, thanks Jeff.
11. Re: Deinterlacing Question
Jeff Bellune Feb 4, 2010 5:06 PM (in response to Ann Bens)You're welcome.
Manuals tend to describe how things are supposed to work, not why
things work that way.
-Jeff
12. Re: Deinterlacing Question
Blue_Devil1 Feb 4, 2010 6:56 PM (in response to Jeff Bellune)Jeff,
Since you mentioned that CS3 makes a progressive frame out of two fields, perhaps if there is little change in the two fields over time (1/30th sec) then when the two non-delinterlaced fields are put together, it wouldn't be noticeable. However, with rapidly moving or changing footage like flames, two slightly different fields would be put together, making the lines. I assume that's what you had in mind when you originally told me to do just the flame part of the video. Does that make sense?
I really appreciate your going through this, since it's sort of academic once Adobe fixed it and folks no longer use CS3 much but it's still great info..
In case you want to actually see the video http://vimeo.com/8923241.
Ann,
For some reason, I've never been able to get .wmv to look good, even when I made tutorials, and I was wondering if you would share your settings?
John
13. Re: Deinterlacing Question
Jeff Bellune Feb 4, 2010 7:32 PM (in response to Blue_Devil1)Correct on all counts, John.
-Jeff
14. Re: Deinterlacing Question
Ann Bens Feb 5, 2010 10:03 AM (in response to Blue_Devil1)Sorry John about all the confusion.
CS3 does not quite behave as it should do, if just found out.
I cannot give you settings because i do not have CS3 anymore on my machine.
If CS3 cannot give you what you want i would consider the standalone Windows Media Encoder.
But if you are realy capturing progressive with Cineform you ought not to have these issues.
15. Re: Deinterlacing Question
Blue_Devil1 Feb 5, 2010 11:38 AM (in response to Ann Bens)Ann, I am trying to figure out some type of work flow for using captured AVCHD 1920x1080 60i for both regular DVD's (SD), and the web.
Up until now, I was capturing with Cineform's HDLink and simultaneously converting the footage to Progressive. Then editing and downsizing with Cineform and outputting with AME (CS3) to Mpeg2 for DVD and Mpeg4 for Vimeo. In spite of being against the "conventional wisdom" of "always follow through with your original footage settings", this seems to work well on my HDTV and PS3 I use for playing the DVD's and Vimeo. Theoretically, no data is lost by deinterlacing.
However, I was always careful not to pan rapidly or include any rapid action.
From what Jeff said above, I assume that you don't lose any data if you just "create" a progressive video from an interlaced video unless you also deinterlace the video you are using to create progressive footage (ie I assume that deinterlacing discards one of the two fields per frame). Again, from what Jeff said, if one has rapid action, then changing interlaced to progressive freezes the artifact causing slight movement between intra-field frames into each frame and there is no way to get rid of it then.
Again, based on above, if I plan to video something where there is action, then I shouldn't convert to progressive but follow through with interlaced. However, at the end with encoding to Mpeg4, it may be best to just deinterlace only the parts with the action to avoid artifact, before converting the footage to progressive so I would save the data in the relatively still areas of the footage (sort of crude Adaptive Deinterlacing).
I realize this is all theoretical and it would be extra work to search out the action parts of the footage, but maybe I'll be able to work it out better in the future. Looks like I'm back to "conventional wisdom" . Naturally, any comments from you and Jeff are always highly regarded.
John
ADD. By the way, how do you output to the web with CS4? Windows Media Encoder always has given me a lot of motion artifacts in the past.
16. Re: Deinterlacing Question
Ann Bens Feb 5, 2010 1:56 PM (in response to Blue_Devil1)Making it progressive or deinterlacing either way you are throwing a way have your vertical resolution.
Now for the web its not that important but a dvd shows like its somewhat 'wooly'.
BR does not alow progressive.
Nowadays i only make wmvHD HDTV720 with max render quality
Tried the H264: was not as good playwise. But i like YT better than Vimeo.
17. Re: Deinterlacing Question
idar lettrem Feb 5, 2010 2:24 PM (in response to Ann Bens)"
I cannot give you settings because i do not have CS3 anymore on my machine."
well, some contributions are better than others . . .
18. Re: Deinterlacing Question
Ann,I guess I don't understand why a progressive frame has half of the vertical resolution. I thought that interlaced recorded every other horizontal line into two different fields for each frame, but progressive records all the lines into one frame.
I also thought if you convert from interlaced to progressive, the computer places both fields into one frame so essentially have the same amount of information.
I thought that was the basis of what Jeff said as to why I got combing (an interlacing artifact) in a progressive frame
"Progressive H.264 export in CS3 goes back to your source footage and then looks at what the sequence is doing to it, if anything. Since you haven't told Pr to deinterlace the footage, the AME constructs a full progressive frame out of the interlaced fields of the source. That results in combing"
Am I wrong here? Thanks,
John
19. Re: Deinterlacing Question
Harm Millaard Feb 5, 2010 4:14 PM (in response to Blue_Devil1)When you make interlaced material progressive, the simplest way (and the one Adobe uses) is to throw away all even fields and just duplicating the odd fields to give you a full frame. That effectively removes half the vertical resolution. I could be mistaken about throwing away even fields, it may be the odd fields, but the effect is still the same.
20. Re: Deinterlacing Question
Jeff Bellune Feb 5, 2010 4:26 PM (in response to Blue_Devil1)I guess I don't understand why a progressive frame has half of the vertical resolution
A progressive frame doesn't have half the vertical resolution. A deinterlaced CS3 frame does. CS3 deinterlaces by throwing out one field (240 lines out of 480) and then filling in the gaps (or, restoring the 480 lines of resolution) by merely duplicating the field that was kept. Since half the vertical resolution (240 lines) was discarded, the resulting image only has half of the vertical resolution of the original frame. Lines 1 and 2 are the same, 3 and 4 are the same, etc. Any detail in the image that was in the discarded field is lost forever.
Your progressive frame that shows the combing has all 480 lines because it combined both fields into one progressive frame, and objects in the frame moved between the time one field was scanned and when the other field was scanned (1/60th of a second). One method to deinterlace the frame and remove the combing artifacts is to remove one of the 2 fields. Once one field is removed, there won't be any combing artifacts because the remaining field represents only one moment in time.
-Jeff
22. Re: Deinterlacing Question
Blue_Devil1 Feb 7, 2010 5:30 AM (in response to lestra7)Thanks. I'd already checked that article out several times. However, the author doesn't mention Jeff's point that Premiere can create Progressive non-deinterlaced footage that will continue to show the "interlacing artifact" or making progressive footage itself doesn't halve the resolution, just the deinterlacing does that. It appears that if one wants to output as interlaced (to get rid of the artifact), you have to do it as progressive since you are left with just one field per frame and your only other choices, I believe would be upper or lower field first ( they give me a blank screen with audio when I output them).
He does mention the term "adaptive deinterlacing" which I borrowed from Jeff when I was talking about a hypothetical workflow..
John
23. Re: Deinterlacing Question
Harm Millaard Feb 7, 2010 6:06 AM (in response to Blue_Devil1)Premiere can create Progressive non-deinterlaced footage
English is not my native language, but something does not sound right here from a linguistic or logical point of view.
Interlaced is the opposite of deinterlaced. So non-deinterlaced is interlaced.
When you have only have two choices, like positive and negative, then non-negative is positive and vice-versa.
So what is progressive non-deinterlaced? Is that interlaced or progressive? Help me understand what you mean.
24. Re: Deinterlacing Question
Jeff Bellune Feb 7, 2010 6:36 AM (in response to Harm Millaard)Harm,
Read my earlier posts. If you don't explicitly deinterlace in CS3, then exporting progressive results in a progressive frame that contains interlacing artifacts.
CS4 changed that behavior; if you export progressive in CS4, then Pr automatically deinterlaces your interlaced footage.
-Jeff
25. Re: Deinterlacing Question
Harm Millaard Feb 7, 2010 7:37 AM (in response to Jeff Bellune)I did read those posts, Jeff, and I understand you, but I don't get the sentence:
Progressive non-deinterlaced. That is the same as: PROGRESSIVE INTERLACED. Great that Adobe can do that, but what is the result? Interlaced progressive or progressive interlaced and what are the differences? If yes, why not?
26. Re: Deinterlacing Question
Jeff Bellune Feb 7, 2010 7:52 AM (in response to Harm Millaard)Progressive non-deinterlaced. That is the same as: PROGRESSIVE INTERLACED
I think he's just describing a progressive frame that has interlacing artifacts.
So:
- interlaced footage viewed on an interlaced display device: no combing.
- interlaced footage viewed on a progressive display device: combing.
- "progressive interlaced" footage viewed on an any display device: combing.
The "progressive interlaced" footage has artifacts because the combing was baked-in when the progressive frame was created.
Does that help?
-Jeff
27. Re: Deinterlacing Question
Harm Millaard Feb 7, 2010 7:57 AM (in response to Jeff Bellune)Adding the word from helps.
Progressive from non-deinterlaced or interlaced material.
