Hi ,
I am getting error "Channel.Connect.Failed error
NetConnection.Call.Failed: HTTP: Failed: url: '
http://localhost:8080/messagebroker/amf'"while trying to create RemoteObject Connection.
I deployed services-config.xml and remoting-config.xml in
webapps\sample\WEB-INF\flex directory.
Files code are .
webapps\sample\WEB-INF\flex\services-config.xml
<?xml version="1.0" encoding="UTF-8"?>
<services-config>
<services>
<service-include file-path="remoting-config.xml" />
<default-channels>
<channel ref="my-amf"/>
</default-channels>
</services>
<channels>
<channel-definition id="my-amf"
class="mx.messaging.channels.AMFChannel">
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>false</polling-enabled>
</properties>
</channel-definition>
</channels>
<logging>
<target class="flex.messaging.log.ConsoleTarget"
level="Debug">
<properties>
<prefix>[Flex] </prefix>
<includeDate>false</includeDate>
<includeTime>false</includeTime>
<includeLevel>false</includeLevel>
<includeCategory>false</includeCategory>
</properties>
</target>
</logging>
</services-config>
webapps\sample\WEB-INF\flex\remoting-config.xml
<service id="remoting-service"
class="flex.messaging.services.RemotingService">
<adapters>
<adapter-definition id="java-object"
class="flex.messaging.services.remoting.adapters.JavaAdapter"
default="true"/>
</adapters>
<default-channels>
</default-channels>
<destination id="Employees">
<adapter ref="java-object"/>
<properties>
<source>com.trivium.SRMSequenceDAO</source>
</properties>
<channels>
</channels>
</destination>
</service>
and web.xlm
<display-name>Flex data</display-name>
<description>Flex data</description>
<!-- Http Flex Session attribute and binding listener
support -->
<listener>
<listener-class>flex.messaging.HttpFlexSession</listener-class>
</listener>
<!-- MessageBroker Servlet -->
<servlet>
<servlet-name>MessageBrokerServlet</servlet-name>
<servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
<init-param>
<param-name>services.configuration.file</param-name>
<param-value>/WEB-INF/flex/services-config.xml</param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/messagebroker/*</url-pattern>
</servlet-mapping>
<session-config>
<session-timeout>35</session-timeout>
</session-config>
<mime-mapping>
<extension>html</extension>
<mime-type>text/html</mime-type>
</mime-mapping>
<mime-mapping>
<extension>txt</extension>
<mime-type>text/plain</mime-type>
</mime-mapping>
i also set Additional compiler arguments property of flex
compiler by
-compiler.context-root /WEB-INF/flex
and i am trying to accesse remote object by
<mx:RemoteObject id="srv" fault="faultHandler(event)"
showBusyCursor="true" destination="Employees">
</mx:RemoteObject>
If any body know solution so please reply
Thanks and Regards
Neeraj
