Hi
I am just starting out using captivate 4 and have recorded a task in excel where I am separating data in a column to another column, by using the 'Text to Columns' option. When I hve recorded in the training simulation mode it has not picked up the fact that I inserted a ( . When I play the piece back the hint box states enter 9. Then when I added ) it is stating I need to insert ).
Can anyone help and tell me where I am going wrong?
Thanks Helen
Hi there
Unfortunately, while the capture process is pretty good, it's not perfect. So it may not capture everything perfectly or even understand what it is capturing in some cases. To be honest, I'm surprised it works as well as it does!
However, this doesn't really address your issue. I'm at a bit of a loss here trying to understand exactly what is happening. I'm wondering if seeing it first hand would assist in sorting the issue. If you can, try using either screenr or jing to record the process where it is failing so that we can see. Then post the link here for us to examine.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Hi
The link to the recording is http://screenr.com/Ijd
Kind Regards Helen
Hi Rick,
Was wondering if it is not due to the used keyboard? I'm using AZERTY - Belgian version, have to translate quite a lot of shortcuts such as CTRL-0/1/2/3 for zooming becomes CTRL-à&é".
Lilybiri
